Capvermell
- Joined
- 5 Jan 2014
- Messages
- 349
I have just spotted a weird addition to Southern's timetable tonight in the shape of the additional 0024 service originating at Sutton and running south through all the usual stations via Dorking to Horsham except that this train is a Set Down Only at all stops en route effort instead of just south of Dorking as the 2325 from Victoria is once it leaves Dorking at 0026. This special extra late night train can be seen at www.realtimetrains.co.uk/service/gb-nr:X58428/2022-10-26
The reason this additional extra service from Sutton to Horsham appears to be running is because the regular 2325 from Victoria to Horsham via Dorking is being diverted after Clapham Junction due to engineering works via Selhurst, West Croydon etc to Sutton hence missing out Mitcham Eastfields, Mitcham Junction, Hackbridge and Carshalton. But instead of Southern running a Rail Replacement Bus all the way from Balham to Dorking as you might perhaps expect they are running an RRB from Balham (leaving 2319) through to Sutton (arriving Sutton at 0016) and then the extra train from Sutton at 0024 all the way down to Horsham and arriving at Horsham at 0113.
But the question surely arises why are Southern doing this when you would think it would be simpler to run an RRB from Balham to Dorking to cover the missing rail service and there should be no need to run it south of Dorking because Holmwood, Ockley and Warnham have already been served on a Set Down Only basis by the 2325 train from Victoria diverted via Thornton Heath and West Croydon. Running a whole extra train from Sutton to Horsham seems like a huge and unnecessary cost by those doing the scheduling compared to just running the RRB down to Dorking. Also in the real world just running the RRB from Balham to Sutton and offering taxis for any unlikely theoretical passengers trying to travel from Mitcham Eastfields, Mitcham Junction, Hackbridge and Carshalton beyond Sutton (there would probably be none as almost no one gets on instead of off the train at these stations going south at this time of night) would seem like a cheaper option.
Bottom line is that this seems like inefficient train planning to cope with engineering works between Clapham Junction and Sutton that isn't necessary when an RRB from just Balham to Sutton would almost certainly have sufficed.
