We need High speed Rail, but Is HS2 really Needed?
Have you thought up any reasons yet why anyone who is at all concerned for Liverpool's future economic health should support HS2 in its current form, beyond 'take one for the team' ?
How about, for starters:
Because it enables a significant reduction in journey times from Liverpool to the heart of the UK economy
Because it enables a doubling in capacity for journeys from Liverpool to the heart of the UK economy
The capacity it releases will enable more trains on the conventional network, for example additional freight services to Liverpool docks
The construction of the line will provide business to several companies in Liverpool in the 14 year construction period
The case for a future extension to Liverpool becomes much better than as a stand alone project
How would your views change if the line went to Liverpool and not Manchester? Or if it stopped at Crewe?
The Ham
6 Jul 2012
If HS2 had not been designed to serve 4 cities only at ludicrous expense, it would in fact be possible to use the money earmarked for it to improve the railway network generally over a much wider area
There's a few points that you seem to be missing:
- multiple towns and cities not on HS2 will benefit from faster journey times and/or more capacity.
- many of those benefits are currently hidden because the opening of HS2 is too far away, however the ITT's of several of the existing franchises will make for In very interesting reading once HS2 is open.
- how much money has been spent on improving the classic rail network since 2009? How much more will be spent until HS2 is open? Maybe it won't be as much as HS2, however it will be very significant. I would suggest given how much impact engineering work has caused increasing this further to provide more improvements probably wouldn't go down as well as some people think. By building HS2 it allows more works to happen whilst impacting fewer people, as such to have a major program of works on the existing network building HS2 would be a distinct advantage.
- HS2 will, even without any additional works, will provide significant capacity to the existing network. For example the XC services between Birmingham and Leeds or Manchester will have more seats available as significant number of those traveling between those two points will use HS2. It is also the case, because of the removal of WCML services, that other TOC's (possibly including XC) will be able to have more paths available to run more services.
B&I
1 Dec 2017
Oh I have no doubt that HS2 will speed up journeys and improve capacity. But the point you don't seem to be getting is that that doesn't really make much difference in comparison to the risk that the economy of the city where I live and work will shrink as a result of it.
Now, you may not have noticed, but since 2010 we have been goimg through a period of.constraints in.government spending. As the government have recently admitted that the deficit which was meant to have been eliminated by 2015 will still be with us in 2031, there is a possibility that this will be witj us for a bit yet. One feature of austerity has been a radical reduction in grants to local authorities. By the end of the decade, the grant to Liverpool will have been reduced by over 60%.compated to 2010 levels. (You might wonder whether the general public's lack of support for HS2 has anything to do with it questionning why £50 bn is being spent on a railway which benefits a handful of places,, chief among them London, at a time when spending is being cut everywhere else).
Now, to make up for reduced central government grants, cities are being expected to increase their rates and council.tax revenues. As the whole country outside London has been in recession since 2008, cities must therefore fight between each other for their share of a shrinking pie. This is why economic growth, or shrinkage, matters more to people in cities like Liverpool than the possibility of getting a go on a big, shiny new train.
Let's look at the benefits of HS2 from the point of view of someone living in Liverpool. We get 1 extra train an hour to London which is 30 minutes faster. I should sa6 we get this for part of.the day, as Liverpool already haa 2 TPH to London in certain hours. The trains will be shorter than the class 390s, and will therefore have fewer seats, or be more cramped. The trains will spend 40 miles on clasic tracks taking longer to get to Crewe than the current trains do. As HS2 does nothing to.relieve capacity for this dtretch except relocating 1 Anglo-Scottish service per hour, and in particular does nothing about the 2 track bottleneck at Winsford, the prospects of any more services to Liverpool from the south or east, or any better local services on these lines, remain approximately zero. As Liverpool services are expected to cater for Crewe demand as well, they will be more crowded from day one of HS2 phase 2b opening than everywhere else's. Our Birmingham service will remain a glorified commuter train, taking 1 hr 47 mins to cover 98 miles, at an average speed of 55 mph, because HS2 hasn't, it seems, even contemplated a Liverpool-Birmingham service. These improvements to XC of which you speak (forgetting for a moment that XC could be improved overnight by buying enough trains to run it properly, and assuming that XC services would continue to run in parallel with HS2 when the DfT clearly despises XC as it is, and seems determined to run it down further) will bring us precisely zero benefit because we lost XC services in 2003, because there are no plans to restore them, and because we remain the second worst city in Britain for long-distance rail connectivity, a situation that HS2 will do little to help with. There will be no effect at all on the slow and infrequent services we currently 'enjoy' to other northern cities, no improvement to local services, no relief for the dangerous levels if overcrowding at our busiest station, and no lilelihood of improvement to the city's traffic congestion, described last by the NIC as Britain's second worst.
So, in return for a slight improvement in service, we get the risk of a shrinking local economy. That would mean fewer jobs and / or less money for what jobs there are. So again, would you like to explain why anyone in Liverpool should support HS2 ? I repeat that 'taking one for the team' is unlikely to prove a popular option.
PR1Berske
27 Jul 2010
But if the DfT chooses not to allow franchise borders to become more flexible after HS2, what use would those extra services be, I wonder?
PR1Berske
27 Jul 2010
I love this post, for being able to articulate what I so often fail to do.
I live in Preston, outside the economic magnet of Manchester. Our roads are clogged, our railways badly in need of investment.
For us, HS2 offers little. As you rightly say, being on a geographic limb seems to mean that the already spurious advantages of the scheme reduce to nowt. That's what I believe will happen to Preston. Having to wait many, many years for the new project to get to Birmingham from Euston, then many, many more years for it to get to Piccadilly. Not one single specific advantage for Preston.
I believe this can be replicated across the country. You in Liverpool, doomed to suffer slow line hell because the route is inadequate. Preston to become a wrinkled observer because, as usual, Manchester is an investment sponge.
Adding this to the fact that the only intercity line we have becomes downgraded to a slow stopper after HS2, as confirmed on here, I have to again ask what's the point of giving London Euston an extra railway line?
B&I
1 Dec 2017
Let's go through those:
More frequent and faster.London services for part of the day: substantially less relevant than a potential reduction in the size of the city's economy.
Releases nore capacity onto.the conventional network: not within 40 rail miles of Liverpool it doesn't. In particular, because of the lack of relief for the 2 track bottleneck at Winsford, the removal of only 1 TPH from this section by HS2, and the introduction of a sexond London train per hour, my rough calculation is that HS2 will permit..... approximately zero extra trains per hour to Liverpool. TfN has already pointed out that HS2 does not provide Liverpool docsk with any extra rail capacity.
Some Liverpool firms might grt some business from.the construction of HS2: they might, but they might from any infrastructure project. And in any case, any money they make would be substantially less than the potential reduction in size in Liverpool's economy, post-HS2.
Better prospects of a high speed line to Liverpool if HS2.is built than if it isn't: I'm struggling to believe that you actually wrote this. Of course Liverpool won't get a high speed line if HS2 isn't built, because there'll be no high speed line for it to link to. If HS2 doesn't currently provide for a high speed line to Liverpool, how will the creation of high spees lines to.other places make it more likely that Liverpool will receive the high speed line that there is currently no plan to build to it ?
Thank you for trying, but I think I'd rather forego the risk.of the economy of the city where I live and work shrinking, if these are the 'benefits' on offer.
Now, I am at risk.of fulfilling the.old adage about asking stupid questions amd getting stupid answers. Nonetheless, if a proper high speed.line was built to Liverpool, and it was no longer at a disadvantage compared to.competing cities re journey times, capacity and frequency of service, that would remove some of my objections. If it stopped at Crewe, I would also be happier than I am now, since it is unarguable that Liverpool will receibe no benefit at all frim any part of HS2 built past Crewe, and because stopping there would eliminate the risk of economic shrinkage that phase 2b would create. However, in either case, my view would remain that overall, HS2 is an extravagent, badly planned, badly managed, wasted opportuity, whixh is unlikely to benefit most of the country.
krus_aragon
10 Jun 2009
North Wales
If we're going to play a game of "who suffers most", I'll point out that the North Wales Coast suffers the additional handicap of not being electrified. As the classic-compatibles are due to be electric-only, we're hoping for some bi-mode stock to replace the Voyagers on the WCML. Bi-mode, non-tilting (slower) stock with additional station calls along the WCML is pretty much a best-case scenario for us in the long term, unless NR's electrification programme gets out of the political quagmire.
Still, I won't argue that the (high speed) London-Birmingham relief line isn't neccessary.
PR1Berske
27 Jul 2010
To me discredit I've not thought about the North Wales line often in this debate, you're absolutely right to point out the problems there. Investment should always be regional and focused, I've said that from day one, and perhaps North Wales shows what happens when the big money items win over regional priorities. For you and thousands others across North Wales, you'll be waiting years and years for a high speed line to connect Euston with Birmingham with the far-off distant promise of *worse* services afterwards than before!
B&I
1 Dec 2017
Thank you, though I'm not sure I'd call it.particularly articulate myself.
I suspect you and I share a different focus to many on here. We live outside the privileged circle of places directly served by HS2, in cities wh9ch are likely to see little, if any benefit from it. This is why.we find it hard to get excited about trains just for being new and shiny.
I may be happier than you are with the concept of high speed railways in general. I recognise that tbete are numerous places where they are the only way to improve rail services, including the southern WCML, which is why I've no problem with a by-pass line being built which would cut journey times to everywhere in the northwest and Midlands served from London. I want to.see that approach applied to numerous places across ths country which are outside the scope of HS2, nost obviously east-west links across the north. What I have a problem with is vast sums being spent for the effective benefit of a handful of places, while rail services, and everything else, are left to moulder across the rest of the country. Like so much else in modern Britain, HS2 is clearly intended to benefit a small minority of the population, regardless of its effects on everyone else
AndrewE
9 Nov 2015
The "N Wales"problem will apply in lots of places. As Hetlana said in another thread
At a bare minimum all the mainlines are trunk routes should have been electrified as well as all suburban commuter routes.
By Mainline I mean:
  • Midland Main line
  • Chiltern
  • GWML down to Penzance
  • Cross Country
  • All Transpenine Express routes
  • Edinburgh- Aberdeen and Edinburgh to Inverness
  • South Wales Main Line
  • North Wales Coast Line
The fact that all of the above have been neglected is quite frankly unforgivable...
and leaves us again in the position that places that get a (further) transport upgrade leave those not connected even further behind. Bringing the national rail network up to the same standard is probably more important for sharing round the economic development and protecting social cohesion than extra capacity to allow us provincials to commute from even further away into London.
The other option you'll have is to change at Crewe for HS2. I wonder how many people will choose the slower direct service, and how many a connection? This might dictate the long term plan.
I have wondered if it'd actually make sense to run the North Wales Coast service via Shrewsbury and onto Chiltern, perhaps using LH Mk4s. This would of course be slower, but perhaps could be hourly as compensation? Then we could reinstate Birmingham-Holyhead via Stafford to replace it on the North Wales Coast, with lots of connectional opportunities onto HS2.
Really what is needed is the wires to Holyhead and the new Welsh franchise ordering bi-modes rather than more DMUs.
krus_aragon
10 Jun 2009
North Wales
It may be the more practical option, but there'll be grumbling about loss of direct trains,etc.
Bangor to Euston is currently ~3:15 direct. Bangor to Birmingham via Shrewsbury by current services takes slightly longer (with a reversal at Chester), before you get to the Chilterns. Plus you'd need infrastructure upgrades between Chester and Shrewsbury if you were going to add an hourly train to London on top of what W&B are planning. Holyhead to Crewe (Stafford, and Birmingham) is probably more practical once HS2 makes some space.
With regards to the new W&B stock, ordering (more expensive) bi-modes, given the story of railway electrification over the past five years, would have been exceedingly optimistic. If the SWML were still being electrified to Swansea then yes, there ought to have been bi-mode stock for Manchester-Milford services, for example, but the only Welsh wires the W&B long-distance fleet can expect to see are between Cardiff and Newport.
I think electrification of the North Wales Coast as a Barnett consequential of the HS2 funding spent in England would have seemed very appropriate, but we were told that HS2 will already benefit Wales as a whole, so Barnett isn't relevant.
krus_aragon
10 Jun 2009
North Wales
You still get strong winds during storms and OHEL is pretty weak against stormy weather.
Of greater issue is how you electrify railways in cast iron tubes and through medieval town walls. BR did a study in the 1980s, and I'm told by a driver of the time that Conwy was seen as a major headache. The reports are in the National Archives in London, but I've not been able to get there to look at them myself yet.
PR1Berske
27 Jul 2010
Yeah reading some of your posts, I think that's the only difference between us. Both agreeing that HS2 will leave the regions behind, even putting some regions backwards; but you from a broadly supportive perspective and me from predominately anti-.
AndrewE
9 Nov 2015
several options straight away:
1) gauntlet the track through the Conway arch itself (& probably the station too) but that would be operationally quite inconvenient
2) rebuild the railway arch through the wall in the same style but bigger
3) use the slow speed/restricted clearance pantograph we imagined for the Forth Bridge job where the same constraints apply. I.e. a narrower lower pan that is used where line speed is low and finding clearance for the horns is difficult. Most trains have multiple pantograph wells now.
And the bridge is wrought iron, not cast. Apparently cast iron columns were added, supposedly to reduce the weight of the bridge according to Wikipedia, which is a bit garbled.
sprinterguy
4 Mar 2010
Macclesfield
Preston will have:
At least two, possibly three (Same as Manchester), trains an hour on HS2 to London from the get go,
An accelerated hourly anglo-scottish service to Birmingham via HS2 once Phase 2 opens,
As well as whatever residual WCML service remains.
With the full Phase 2 western arm in place journey times to London are expected to be reduced by 44 minutes, to 1 hour 24 minutes, and with the acceleration of construction of the line as far as Crewe will realise most of this time benefit years before Phase 2 opens through to Manchester (assuming it ever does). I'm unsure how this can be construed as a degradation in service for Preston.
And Preston is tiny compared with Manchester, and even now punches well above its weight in rail service terms because of its location. Crewe is a more extreme example of this, but Preston is not dissimilar really.
AndrewE
9 Nov 2015
However both are important junctions on the railway network, which is why so many trains call.
We recognise that there will never be through trains from everywhere to everywhere, which is why good connections at these nodes are so important.
Hence my continual reminders/complaints that there is only 1 train per hour northbound on the WCML proper from Crewe, going alternately to Glasgow and Edinburgh which is completely inadequate.
krus_aragon
10 Jun 2009
North Wales
Quite right. Perhaps the original Dee Bridge wandered into my mind for some reason. (The very eary plans were for cast iron arches over the Menai and Conwy, but wrought iron was the thing for tubular bridges.)
The columns at each end were added in September/October 1899, according to Peter Baughan (C&HR, Vol 1).
PR1Berske
27 Jul 2010
At least two, probably three (Same as Manchester), trains an hour on HS2 to London from the get go,
How many years between these Phase 1 and Phase 2 improvements, by your estimation, though? I can't see why it's necessary for the regions to wait and wait and wait, it's been this sorry state of "Investment will come, just keep holding on" for generations, how are we still championing the same thing now as progress?
sprinterguy
4 Mar 2010
Macclesfield
Six years. Though as I say, Preston won't be waiting and waiting for most of the London service improvements, due to the proposed opening of the Crewe link in 2027. Preston will benefit from HS2 as soon as Birmingham and Manchester will, and due to the Crewe link will probably have an advantage over Manchester for several years.
Much as I think the fast Scottish train should call on the Taktfahrplan principle, there's also the argument of who needs it? Crewe itself doesn't (it's even smaller than Preston and has relatively little demand that isn't coming in by car and so couldn't drive elsewhere instead), and for connecting from MKC the 1tph *is* adequate. North Wales doesn't as there are 2tph from Warrington BQ, served directly from the busy bits of North Wales. Where does?
B&I
1 Dec 2017
Isn't it lucky that Crewe, Milton Keynes and North Wales are the only places on the western side of non-Scottish Britain from where anyone wants to travel to Scotland ?
AndrewE
9 Nov 2015
For which specific place is the present hourly service inadequate?
I tried to point out that people coming through the gates at Crewe are not the only ones to be considered - maybe the terms Junction and
have different meanings for other people? The Shrewsbury and Stoke lines feed a lot of people into the northbound class 9s, which are already heavily loaded from the West Midlands.
And by the way, it's a train per hour, but alternately to Glasgow and Edinburgh.
The Ham
6 Jul 2012
Yes we get it, you think that Liverpool will wither on the vine solely because HS2 won't run to Liverpool.
Yes, at peak hours there's no increase in frequency, however that only accounts for about 25% of services. Most people would therefore be able to have a wider choice of trains.
If anything having shorter more frequent services should help with justifying a proper HS line to Liverpool, in that once those services are busy there's no scope to lengthen those trains without the HS line.
One of the things you seem to be overlooking is that because journey times to Liverpool are likely to improve (even if not to every location and those which are slower would only be by a few minutes, for instance 40 miles at 110mph rather than 125mph is an extra 2 minutes 37 second, however that time difference will be less due to real world travel rather than flat out speed), as such there's likely to be some improvements as well as some losses. Overall the difference probably isn't going to be overly that noticeable.
I'm aware of some of the impacts of the financial crisis 10 years ago and how that has impacted on government policy and how local authorities are having to make cuts, in some cases by trying to avoid their legal duties so that they can save money.
I would suggest that it's getting to the point where austerity is casing problems to the vast majority of people and so the political impact of it could be quite significant at the next election.
As to what will happen with XC services is up for debate at present, which may result in longer trains over the next franchise, however the point I was making was that by 2027/2033 (which is likely be during the following franchise to the next one) having extra paths for XC services maybe required (regardless of how long the trains get).
