WCML Disruption (07/11)
nr_signaller
6 Feb 2011
Considering the signalling has not even been upgraded yet, it just proves how much this upgrade is needed!
Tetchytyke
12 Sep 2013
Isle of Man
More signalling problems again today. It never ends.
Still, I'm now up to sixty quid of delay rail vouchers (which is impressive as a 30 minute delay is only £3.50), so that'll pay for a nice rail rover in the spring.
carriageline
11 Jan 2012
Actually, the problems recently have been with upgraded/recently added signalling.
Sent from my iPhone using Tapatalk
moggie
2 Jan 2010
West Midlands
Piecemeal modernisation of the signalling tied to a piecemeal alteration of the Pway means more intrusive activity around the existing signalling circuits, cables etc etc. The failures may or may not be occurring on whatever new kit is working, but constant changes to prepare for forthcoming works or just physically near what is presumably fragile existing kit has clear potential to quickly exposes the weak parts of any installation, hence a predicable increase in failure rates. One reason why it's being renewed no doubt. Nothing new, happens at pretty much every worksite no matter what precautions are taken.
Then they wonder why those in the know think new build a'la HS2 is not such a bad idea.
All Line Rover
17 Feb 2011
More disruption on the WCML this morning. Signalling problems through Watford Junction (again) causing delays of up to 45 minutes.
tsr
15 Nov 2011
Between the parallel lines
Track circuit issues on the mainline have apparently been resolved - I am not sure about the track circuit defect on the Overground route at Hatch End. There was also a breakdown on the St Albans Abbey branch earlier (unit brake failure).
Kristofferson
23 Nov 2012
This is getting silly now. The WCML has gone from one of the most reliable railways in the country, to a joke that rivals the GEML for unreliability.
Dear Network Rail... just give up, pack up, and go home. If it ain't broke, don't mess with it!
All Line Rover
17 Feb 2011
Now there are also delays of up to 1 hour between Stafford and Birmingham due to (you guessed it!) signalling problems.
carriageline
11 Jan 2012
Well, if it's breaking then it's quite clearly broken? :lol:
The resignalling works HAVENT added anything to the current signalling system. Maybe it's just bad luck?
Kristofferson
23 Nov 2012
But if they haven't done anything, why are there so many signal/track circuit failures recently?
Kristofferson
23 Nov 2012
Moggie's post further up is probably what's happening.
Right, that's what I thought. They should have either closed the line over August and done it properly (for all the moaning commuters would do, let's be honest, they wouldn't have minded an extra month's holiday... sorry, "working from home") or left it alone.
Tetchytyke
12 Sep 2013
Isle of Man
They sort of have and sort of haven't. Many of the new signals are now in place, especially at the north of Watford, where today's signal failure was. They're not activated, but the infrastructure is in. I've seen others on here, like Moggie, mention that the issue seems to be the new hardware is trying to operate when it shouldn't, and it's confusing the system. I'm no signalling engineer so I don't know if that's true, but it would figure.
It should have been done properly or not at all. The current situation is ludicrous. It may hopefully get a little better in December; the equipment will still be rubbish but the "Watford flyer" from Junction to Euston will not be running, so there are fewer trains.
tsr
15 Nov 2011
If you refer to today's issues, there are still some delays of around 15mins and a few cancellations, plus disruption to LOROL in the area. Hardly "quickly resolved".
carriageline
11 Jan 2012
To be fair, the equipment that was operating when it shouldn't was the people on the projects fault, livening equipment up that hasn't been commission as of yet.
The problem with engineering works (or any works for that matter) where your working around live equipment, even worse if it is life expired, is your bound to disturb something. Things can trundle along for years, but if it gets disturbed and breaks contact then you get faults like this (not saying this is what has happened!). It is also why faults fell 'overnight' during the Olympics when no overnight works were taking place, as nothing was being disturbed.
I do admit it is an awful situation to be in, and I feel for pax that have to bear with it.
Tetchytyke
12 Sep 2013
Isle of Man
The delays through Watford were quickly resolved. Everything was back to normal by 10am.
Three hours is not "quickly resolved", and there are still knock-on delays even now.
It's the fifth time in two weeks that I've been late for work due to these issues. It's simply not good enough. The only- small- plus side is that I'm now up to sixty quid in rail vouchers since July, which is impressive given that a 30 minute delay is only £3.70.
oversteer
26 Jan 2011
I've been commuting on that line and despite all these delays only qualify for delay repay today! A set of 20 minute delays is far more annoying than a single 30 minute one .. :(
