WCML Accidents in the 1980s
MarkWi72
13 Nov 2017
I have been listening to the excellent 'Signals to Danger' podcast this evening, the Linslade Tunnel episode. I had not heard about that accident previously, and it was a tragic set of circumstances which led to it. Late running 1S18, terrible incompetence in Toton (unless someone can enlighten me on that regarding the Bogie Bolster being hump shunted, when it was not supposed to be) and the parcels train occupying the down fast.
RIP William Plummer.
I only recall two other significant ones; Watford 1984 and Stafford 1990.
Helvellyn
28 Aug 2009
Carlisle, 1 May 1984, which could have been a very serious accident. A Liverpool-Glasgow Freightliner suffered a broken coupling on the descent from Shap, which saw the rear part become detached - and a runaway. Shows how the WCML descends all the way from Shap to Carlisle. An observant and calm Signaller, Bill Taylor, was aware what happened and set the route up to divert the runaway wagons onto the Carlisle Avoiding Line, where they derailed at 60mph demolishing a bridge over the River Caldew. The damage was so severe that it led to the closure of the Avoiding Line. If the Signaller hadn't been aware and responded as he did the runaway wagons would have been routed into Citadel station where it's likely they'd have derailed on the track layout and the chances of people being injured, or even killed, would have been very high.
Beebman
17 Feb 2011
Twyford
Wembley Central 11 October 1984 - a 2 x 310 set SPAD'ed a signal and hit the side of a Freightliner train resulting in 3 fatalities, one of whom was the EMU driver.
Helvellyn
28 Aug 2009
Colwich Junction 19 September 1986.
RIP Driver Eric Goode
Having seen the aerial shots of the aftermath it's a miracle there was only one death (and that was one too many). Especially as there was a Mark 1 RBR in the consist that was wrecked.
MarkWi72
13 Nov 2017
Ah, that rings a bell. Am I conflating this with Watford Junction? I think there was a Watford Junction derailment in 1996, too.
Helvellyn
28 Aug 2009
A
A SPAD with a Class 321/4 in passenger service saw it in a collison with another Class 321/4 (ECS) that was making a crossing move. One passenger unfortunately was killed.
At least two replacement Class 321 driving vehicles were built at Crewe Works due to the severity of the damage to the two units that collided.
Sir Felix Pole
21 Oct 2012
Wilmslow
Bushey, Feb. 1980. Down Manchester derailed at 96mph due to a broken weld on CWR. Miraculously no one was killed which was a tribute to the strength of the Mk III coaches. It was a tricky operation to retrieve the Cl.87 at the bottom of the embankment.
43096
23 Nov 2015
The 87 was derailed but did not go down an embankment. Are you thinking of the Watford collision in 1975 that deposited 86209 down an embankment?
Helvellyn
28 Aug 2009
So we have:
  • 16 Feb 1980 - Bushey derailment
  • 9 Dec 1982 - Linslade Tunnel accident
  • 1 May 1984 - Carlisle Avoiding Line freight train derailment (runaway)
  • 11 Oct 1984 - Wembley Central collision
  • 13 Nov 1984 - freight train derailment on Stockport viaduct
  • 19 Sep 1986 - Colwich Junction collision
Skiddaw
2 Jan 2020
Penrith
Goodness! I'd not realised the descent after Shap was as significant is it is. Fair play to the Signaller.
Why didn't the driver notice he'd lost the rear part of his train?
Helvellyn
28 Aug 2009
There's no accident report on the excellent Railways Archive site, probably because there were no fatalities and it involved a fright train. However, is an excellent article at Rail Engineer that explains the causes and also the actions Bill Taylor took.
If you Google "Carlisle Accident 1984" there's a lot of photos online, especially Facebook of the immediate aftermath. Once the clean-up had happened you can understand why reinstating the line never happened.
ChiefPlanner
6 Sep 2011
Herts
From memory , the train was re-marshalled at Crewe , with a portion detached and a section from Liverpool to Glasgow attached. Unfortunately the "new" section was hooked on , not with a proper Freightliner short green strengthened coupling but a passenger red coupling was used. Train stopped at Preston with a report of sparks noted , those attending isolated the rear section and checked the wheelsets but apparently / allegedly failed to carry out a full functional brake test.
Once over Shap - the rear section , now a "swinger" buffered up to the front fully braked section and the longer red coupling climbed over the drawhook dividing the train - the train powered on towards Carlisle but the rear section followed on the down grade with a gap between the 2 portions. I believe some one trackside rang the PSB reporting the fact , but the latter noted it on the panel and with commendable prescence of mind diverted the rear section onto the freight avoiding line where it traversed some of the curves but eventually piled up. Some of the wrecked wagons carried Octel tanks (highly dangerous) , but the very robust construction survived , but the local bird population no doubt enjoyed the spilt grain from some of the containers. There was a consignment of brand new street signs in one of the boxes destined for Aberdeen - which were jettisoned all over the place. Recovery was a major job which neccesitated both the evacuation of some of the local residents and also the de-watering of the River Caldew.
Skiddaw
2 Jan 2020
Penrith
Thanks both.
Just been looking at the FB pics. It really was a near miss wasn't it! Glad to see the on the ball signaller later had an engine named after him.
norbitonflyer
24 Mar 2020
SW London
A colleague of mine was on that train - his regular commute. Only a minor physical injury to his hand, but the experience probably contributed to his decision to take early retirement a year or so later.
sh24
28 Sep 2023
It's quite a list. How much quieter was the WCML then? I'm assuming much higher passenger numbers now but less freight.
hexagon789
2 Sep 2016
It's quite a list. How much quieter was the WCML then? I'm assuming much higher passenger numbers but less freight.
Well in 1986, Liverpool and Manchester had both been downgraded from hourly (Liverpool in 1984, Manchester in 1985) to approximately every 90 mins off-peak.
Glasgow was broadly two-hourly but IIRC only 5 per day since 1985.
Birmingham fast was half-hourly.
Holyhead and Blackpool each had 3 per day from memory.
There were a few odd other workings and bits and pieces.
I presume the Birmingham semi-fasts (using 310s, later 321s) were half-hourly but I'm not sure.
Frequency on the InterCity services were reduced as economy measures throughout the early and mid-80s from a high point introduced in the 1974 timetable.
Most of the off-peak reductions were restored in 1989 and 1990 but not all.
Clarence Yard
18 Dec 2014
87007 didn’t end up down the embankment - you are confusing it with 86209, which did in 1975. 87007 wasn’t even derailed.
A temporary road was built across the water meadow to recover 86209, which was taken on a trailer from Water Lane, round the infamous Watford one way system the wrong way (!) and finally off down the M1 towards Crewe.
Tester
5 Jul 2020
Watford
I was at college then, overlooking 86209 from the classroom window was a bit of a distraction!
Helvellyn
28 Aug 2009
Overnights were busy, with a lot more Sleepers plus TPOs and Parcels services. Add in freight and somewhere like Carlisle was extremely busy.
Also had the through CrossCountry daytime services that could be load 11 on the Northern WCML due to serving Glasgow and Edinburgh with portions, plus shorter workings to Birmingham/Manchester.
45Fox
17 May 2022
Leicester
You're correct that there were, regrettably, 3 fatalities but they were all passengers; the driver survived and was subsequently examined by a specially convened board of medical experts as part of the accident investigation, as was his medical history, they concluded that he had most likely experienced a transient episode of a rare but known medical (neurological) condition.
Another WCML accident in the 1980s was at Wigan North Western, in the early hours of 3rd. February, 1984, when a class 6 freight ran into the back of a freightliner train standing at a signal, sadly the driver and guard of the class 6 died. Visibility of the standing train was closely examined in the investigation, it's tail lamp wasn't lit and empty liner flats on the rear made it hard to see in the dark.
