Watford Junction on Travelcard
TT-ONR-NRN
30 Dec 2016
Cambridge
Now you may think this is silly - but bear in mind Travelcards are excepted on Norwich-bound Greater Anglia services between London and Stratford, and the call at Stratford is advertised as pick up only just the same as Watford!
So if I have a Zone 1-6 Travelcard, bearing in mind Watford Junction is in that zone, can I take a Pendolino there from Euston with it?
bb21
Emeritus Moderator
4 Feb 2010
Neither is accepted, as they are both pick-up only.
Watford Junction is not in any of Zones 1/2/3/4/5/6 in any case.
Boarding set down only Virgin Trains services at Watford Junction is quite strictly monitored and will be stopped if you attempt it.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
The 'London Rail and Tube services map' might help you : http://content.tfl.gov.uk/london-rail-and-tube-services-map.pdf
I hope you agree that this map makes it quite clear which stations are in which zones (though it's very messy in depicting the arrangements at Heathrow, and slightly ambiguous with the grey shading around Stratford and Greenwich - neither of which apply to your enquiry).
robbeech
11 Nov 2015
Even if you had a Zone 1-9 + Watford Junction Travelcard and it wasn't pick up / set down only with (as mentioned) strict checks then you'd only be allowed in Standard Class and this might not quite cut it for you ;)
hexagon789
2 Sep 2016
All I can say is: :lol:
cactustwirly
10 Apr 2013
Buy a return from Boundary zone 6 to Watford Junction, you can use it in conjunction with your travelcard
TT-ONR-NRN
30 Dec 2016
Cambridge
What’s that supposed to mean?
Thanks. Is this valid on Virgin?
Not on VT, though. VT does not carry passengers between Euston and Watford Junction under any circumstances, even in disruption. If you want a ride on a Pendolino you're going to have to cough up and go to MKC and back.
cactustwirly
10 Apr 2013
A BZ6 - MKC return would be less risky, but offers poor value for money.
If you want to use Virgin, I'd go for a BZ6 return to Stevenage.
MikeWh
15 Jun 2010
Crayford
No.
Under no circumstances, not even in disruption, can you make a journey from Euston to Watford Junction or vice versa using Virgin Trains. Not with any ticket. Not even a First Class All Line Rover.
Other than breaking the am peak restrictions I fail to see what they can do to stop someone using an all line rover. There is absolutely no revenue loss.
It isn't about revenue loss, it's about crowding the trains out. You might well get away with doing Euston-Watford with a telling off if you have a ticket valid to MKC or beyond, but the other way you will be seen doing it by the dispatchers and they will not dispatch the train until you have left it.
causton
4 Aug 2010
Depends who you get! Most will not let you board though, correct.
In disruption, when there is VT and LNR cross ticket acceptance, the 'set down' trains often get used at Watford to get people to London - so actually, in very rare circumstances you will be able to get on.
It doesn't seem to happen the other way round though, and don't try your luck unless you fancy buying a SOS to Coventry :lol:
causton
4 Aug 2010
Exactly! How hard is it to understand? Watford is not in London and therefore it is not in a zone, just like Amersham... hmm, maybe not... Elstree and Borehamwood... oh wait, just like Epping... oh wait, just like Shenfield Brentwood, wait... Dartford? Potters Bar! There's one!
Back to the drawing board ;)
I can see how it is confusing but it takes mere seconds to look at the very clear Special fares apply on the tube map. London Underground ticket machines you have no excuse as one option clearly says Zones 1-9 + Watford Junction and I have a photo of the screen to show people who buy the wrong one "Why did you not choose the one that says Watford Junction on it?!?!" - I have still to receive a good answer ;)
pitdiver
22 Jan 2012
Warsop Vale
I used to work at Watford Met LUL stn. When there was disruption between Watford Jct and Euston it would give me great pleasure in excessing all those passengers thinking that their tickets were valid there. The LUL Revenue Protection staff would have a field day. And before anybody asks I don't remember any ticket acceptance being invoked. Not saying it didn't occur though.
Darandio
24 Feb 2007
It's no wonder there is often a staff/passenger stand off on this forum.
Mag_seven
1 Sep 2014
here to eternity
No.
Same with PRIV as well but I bet some PRIV holders still try it.
