DarloRich
Yes as the correct technical term for the bridge is I think "knackered".
surely the correct terminology is unsuitable for further life extension works
No it won't. The WCML will have no access into Euston at least 2-4 days a year (outside of Christmas) every year. HS2 won't help any of the stations in Bucks, Herts or Northants.
When I said main I meant the bigger proper cities and longer journies that will be done away with. And as others have pointed out there will be other routes open by then.
So yes, yes it will. And they should build it in your back garden for being a naysayer![]()
HS2 will have it's own engineering work ... Buses and long slow diversions will always be required.
Not for HS2. There will be a suitably wide separation of the tracks, and of course will be fully bi-di. So it will be a similar maintenance and renewal regime as the LGVs, or for that matter HS1, ie all overnight.
Shoulda been done as one long two week blockade as originally planned. Short term blockades such as this are a pain in the arse to diagram, they are a pain in the arse for traincrew, and they are a pain in the arse for the punters.
Luck?? More like a bloody miracle!!
I know they are upgrading the OHLE equipment and signalling but are they going to increase the linespeed through Watford? It is around 80mph northbound at the moment as far as I know.
Marylebone-Aylesbury-Bletchley/MKC will be if it goes via Amersham, a majority of the route is LUL's track. If it does go via High Wycombe, that entails that the entire stretch from Princes Risborough - Aylesbury is 40mph, single track.
... If it does go via High Wycombe, that entails that the entire stretch from Princes Risborough - Aylesbury is 40mph, single track.
NR CP5 said:Installation of a new running loop between Aylesbury and Princes Risborough, if required, to accommodate extension of the proposed East West Rail Milton Keynes – Aylesbury service to Marylebone.
EWR said:Milton Keynes to London Marylebone via Aylesbury and High Wycombe Services are expected to run hourly calling at Bletchley, the new station at Winslow, Aylesbury Vale Parkway, Aylesbury, Princes Risborough, High Wycombe and onward to London Marylebone.
http://www.eastwestrail.org.uk/western-section
The speed limits are already 75mph on the slow lines and 110mph on the fast lines!
Full marks to passengers as it wasn't as busy as I'd expected today, many must have planned alternative routes or not travelled! Didn't get abuse off anyone which is nice...although someone ranted at my colleague that she shouldn't have to pay for the part of the Journey replaced by a Bus!
All the evidence so far is that the EWR Marylebone service will be an extension of the existing service via High Wycombe - the project page in the CP5 plans includes the possibility of an upgrade to the Princes Risborough to Aylesbury line; and EWR themselves have always explained it as running via High Wycombe, and shown that on their maps:
It's really not that hard to fit a train with a tripcock...
It is when they've got Voyager style bogies...I challenge you to try fitting a tripcock to a 172 :P
Fair enough I thought there was a 80mph TSR on the northbound fast line but must have been removed.
But with any luck we'll have Bletchley-Aylesbury-Marylebone,
I "think" (May be incorrect) there may be lower TSRs after the blocks (50 things a bell?) but I can't say for certain!
Sent from my iPhone using Tapatalk
It's all gone very pear-shaped....now doing single line working on the Up Slow from Wembley to Watford due to OHL issues affecting the Down Slow![]()
It says Southern services can't run between Watford Junction and Shepberds Bush. We're they never due to run to Milton Keynes today, like they normally would on a Monday bank holiday? Can't believe they would be the only company running services during the engineering works overrun.
Sent from my Nexus 5 using Tapatalk
Southern always run a Saturday service on Bank Holidays so usually it would run to MKC.
