merlodlliw
he 175s were designed for North Western Trains(part of the franchise requirment if I recall)) , with nothing then due to go further south than Wrexham/Bidston under that franchise.
Little known fact - FNW had "rights" to run 4 tpd per day from Holyhead to Euston - never materialised of course - and the "175" sets were originally intended to be 125 mph to cope with this and other aspirations. Their ill fated attempts to deliver a London service from Blackpool / Rochdale and Manchester Airport with 158 / 322 sets were a sort of compromise on this commitment.
I used the FNW service,boarding at Sandbach(Man Airport) to Euston,VT imposed the non compi forbidding the use of Crewe and other stations, the return fare was £25,a big saving on VT.
Then signs appeared in Euston by VT, Manchester return for £10, that effectively killed off North Westerns London runs before the North Wales/Euston service started, VT also started Manchester/Euston for the £10 spoiler.
The electric trains I caught at Sandbach still had Stanstead Express logos on them, I also recall the 158 sets via Man Vic to London.
The X-Ray programme (featuring ATW) has been moved from its normal Monday slot next week - due to soccer. It will be broadcast on Friday 20 March 2015 at 7.30pm. http://www.bbc.co.uk/programmes/b05n7skj
Unfortunately, the general public think that it is all the fault of the TOC's when they have old overcrowded trains. Presumably, should the Welsh Government set up an 'arms length' company to take over the running of what is not the ATW franchise, electrification will then take place and the general public will think "what a difference it has made getting rid of ATW & having the Welsh Government ultimately in control". On the other hand, if it does happen, it could be a total disaster - especially if the UK government refuses permission for 'Welsh' trains to operate on 'English' tracks. Perhaps we will all have to change at the border crossings such as Chepstow? (Note that over 60's cannot even use their bus passes in each others* 'countries' - goodness knows why they can't have a reciprocal arrangement)? * Apart from limited cross border trips.
In Europe I recall services between Countries, you stayed in the same carriage,but the loco changed at the Border, I hope we dont get to the
same situation, imagine Chester Wrexham area one area,then Gobowen to Salop another area, etc etc
but wouldn't it be cheaper to build unpowered carriages and tow them with a locomotive, which could, when not pulling the carriages could be used to pull goods wagons. You could then add or subtract passenger carriages depending on the expected level of passengers
