richa2002
- Joined
- 8 Jun 2005
- Messages
- 2,296
I've always been curious as to how the engine on a Voyager or Meridian revs in relation to the driver's power handle position.
Is it directly proportional so if you select 50% power for example, the engine will rev to halfway between idle and full, or is it more clever than that as I suspect?
For example, can engine rpm vary even if the driver keeps the power handle in the same position, perhaps due to the load changing as speed is gained or lost?
Also, is there a point for example where the engine reaches full rpm and then simply the load being placed on it changes depending on power handle position?
Any information from drivers or those who know these units inside out would be much appreciated! Thanks.
