MerlinRail 804
Does anyone know how long (time and distance if possible) the voyagers/super voyagers take to accelerate from a stand to 125mph?
Roughly 6mins / 8 miles. Some sets better than others also gradients can affect time.Does anyone know how long (time and distance if possible) the voyagers/super voyagers take to accelerate from a stand to 125mph?
I don’t have any experience of them so can’t say but Voyagers used to be even quicker but had their engines down rated many years agoDoes this apply to the Meridians - as the are apart of the same family?
This video shows a 222 going from 0-110mph in about 3 minutes:Does this apply to the Meridians - as the are apart of the same family?
Eversholt's own performance graphs have the 222s as about 210s to attain 110mph and 320s to 125mph, for what it's worth.This video shows a 222 going from 0-110mph in about 3 minutes:
Is there much difference between the lighter 220's and the heavier 221s?This is accurate.
Standing start from Stafford station to Penkridge platform is around 4 mins / 6 miles @ 113mph and then four ashes loop is another 2mins / 2 miles around 125mph
yes about 10%Is there much difference between the lighter 220's and the heavier 221s?
The heavy outside frame bogies on the 221s add ~10t per car compared to the 220s.It is variable because of different conditions, such as adhesion and gradient. However, the Cummins QSK19, set at 750-752HP can generally propel a coach to 125 miles per hour in around 1 and a half minute to 5 minutes. This will depend on various factors - as I mentioned. As well as this, some Voyagers are slightly heavier than others, due to having tilting equipment and heavy-weight bogies.
When i did find a Class 180 with all engnes running and no transmission issues, these engines are set to the higher 750bhp but the hydraulic transmission bluints performance to the extent that the 0-60 mph time is generally slightly slower. Just looking at one example on levelish GWML track i have 0-124mph in 5min 10 secs and 7.2 miles.It is variable because of different conditions, such as adhesion and gradient. However, the Cummins QSK19, set at 750-752HP can generally propel a coach to 125 miles per hour in around 1 and a half minute to 5 minutes. This will depend on various factors - as I mentioned. As well as this, some Voyagers are slightly heavier than others, due to having tilting equipment and heavy-weight bogies.
Unfortunately, answers to this question will be ambiguous because of how varied the circumstances are. I do remember the First Great Western video saying however, that Adelantes (which use the same engine as Voyagers) can reach 125 in around 4 minutes, whereas a HST can take 10 minutes to get to 125 (their words).
