Virgin Trains EC 1Y44 breakdown (13/07)
gavin
25 Dec 2006
Just seen on Twitter that the 1st Thunderbird broke down and another has had to be called presumably from Doncaster?
Crossover
4 Jun 2009
I would guess that it would have gone straight to Bounds Green from Stevenage, where it terminated. If they followed usual convention, I would expect it to have run as 5Y11
Does anyone know if this was a HST as looking at other dates, this set may then go on to work the Sunderland service?
800001
24 Oct 2015
It was a Mk4 set.
43096
23 Nov 2015
Normal procedure is for failed VTEC HSTs to go to Neville Hill or Craigentinny and Mark 4 sets to go to Bounds Green. In other words, sets go to where the expertise is on that train type.
gavin
25 Dec 2006
1D33 2135 London Kings Cross to Leeds had to be rescued by Thunderbird it must have had a fault for a while as it started losing time from Finsbury Park before eventually giving up between Adwick Jn & South Kirkby Jn originally due into Leeds at 00:08 it finally arrive at 02:53 around 33 minutes after the 23:30 departure from Kings Cross arrived into Leeds
http://www.realtimetrains.co.uk/train/Y60132/2017/07/14/advanced
godfreycomplex
23 Jun 2016
Indeed. Sat down at Frickley Beck (about a mile London side of South Elmsall) at about 00:15. 1Z99 (the Thunderbird) left Donny at about 01:00; suggesting the driver tried to restart the failed train; but the problem was fairly terminal.
The failed train didn't get going until about 02:20 for reasons unclear (I think there may have been some trouble getting the Thunderbird to the front of the train but I'm not sure).
Deep joy....
Adam0984
18 Feb 2014
I'd imagine that the thunderbird would have had to go via Hambleton to get to the front of the train then use the main to main crossover at South Kirby Jcn to get on the front to pull it to Leeds
godfreycomplex
23 Jun 2016
It went via Adwick at first; although the headcode mysteriously disappeared at Carcroft junction and the train started moving an hour and a half later so it must have got to the front somehow.
Hambleton would be more logical; so there must have been some reason it couldn't go that way
Adam0984
18 Feb 2014
Must have gone wrong Road from Adwick to South Kirkby crossover and onto the front then
D365
29 Jun 2012
Try reading through the thread:roll:
Thankfully I did not have to travel by train yesterday, but in the past when I've been delayed on East Coast services you've often made unhelpful remarks, whilst I was concerned with actually finding out when the situation would be resolved.
jonhewes
8 Oct 2008
Out of interest, why was it deemed necessary to detrain the passengers and run ECS to Bounds Green? Kings Cross is less than 6 miles away!
GW43125
8 Dec 2014
because if the set is buggered, taking it into KX would require an extra loco, two reversals and potentially a run round move to get it into Bounds Green for repair. Whereas if you detrain at Stevenage/Peterborough, you can run round the Hertford loop and straight into Bounds Green from the north without having to reverse.
