Virgin cross-channel stock updates
rmHawk765
8 Apr 2025
ECML South
Virgin has confirmed a deal for 12 Avelia Stream-based units for use on cross channel services, competing with Eurostar.
https://www.railjournal.com/regions/europe/virgin-orders-cross-channel-trains/
BRITISH-based passenger operator VTE Holdings (Virgin) has agreed a deal with Alstom to supply 12 Avelia Stream high-speed trains for its proposed cross-Channel services from 2030.
In a submission to the Office of Rail and Road (ORR) relating to an application for access to Temple Mills International depot (TMI) in east London, Virgin confirms that it has “secured binding exclusivity with Alstom” for the supply of the 200m-long single-deck, tilting trains, with the deal expected to be concluded by the end of the year. It adds that all trains will be approved and fitted with relevant safety and signalling systems for use in Britain, the Channel Tunnel, France, Belgium and the Netherlands.
Virgin has updated its requirements for stabling and maintenance at TMI. It says that due to more efficient planning, only one 24-hour slot is required for three weeks in every four to proactively wheel re-profile a complete train, reducing time on the wheel lathe by 520 hours. It will also requires tracks no longer than 200m within the depot area. In addition, three tracks sought for daytime stabling are only required when the wider network is disrupted. Due to the delay in ordering new trains, Virgin says it is now looking for depot access to start in the second quarter of 2028.
Details of the planned services have been confirmed. Virgin expects to operate 20 daily return services from London: 13 to Paris, four to Brussels, and three to Amsterdam. According to the company “services will follow a phased launch plan, with the full timetable in place six months after initial launch in 2030.”
Trainguy34
29 Apr 2023
Kent
Still no Germany or southern France :rolleyes:. If it wasn't obvious enough it was just going after E* it is now.
Hopefully we'll have better spacing for Amsterdam and, if I really want to push the boat out, some stops in Kent!
rmHawk765
8 Apr 2025
ECML South
CGI attached. Looks similar to the Italo 'Avelia Pendolino' units.
  • Virgin-Alstom-2025-07-18-vte-holdings-limited-response-further-information-clarification-and-r...jpg
Trainguy34
29 Apr 2023
Kent
Class 890 perhaps? Just guessing it would be based off of the 390. If we're lucky it might be produced at Derby when that calms down.
E B
30 Oct 2024
Nuneaton
It’s a shame that we aren’t seeing any new destinations - maybe it could change though
Avelia Stream seems to be an Alstom umbrella term for designs as diverse as the Amtrak Acela, SJ Zefiro Express and NTV Pendolino.
Tilting is one of the options (used on the Avelia Liberty for Amtrak).
Bodyshells for the SJ trains are manufactured in China, while the NTV trains are largely from Savigliano in Italy, like the 390s.
With a wide range of applications (from 200 km/h to 300 km/h, options for tilting and/or winter package, short and long-distance configurations, etc.), Avelia Stream™ high-speed trains meets customer expectations by offering multiple configurations and options.
There's also this analysis by Jon Worth:
While Alstom’s website is rather unclear on the point – it lumps very different ex-Bombardier and ex-Alstom Italy products under the Stream label – this train for Virgin would be essentially a souped up non-tilting Pendolino design. The closest equivalents are the ED250 running in Poland and ETR 675 for Italo in Italy, but those have a maximum speed of 250km/h. We know a 300km/h version of this train is in the works, because French high speed startup Kevin Speed intends to buy them, and to secure paths on French high speed lines, 300km/h is a must. But choosing Stream is a risk – these designs have not yet been approved to run in France (and French legacy signalling system TVM430 is going to be needed), and when the new 300km/h version is going to be available is not known.
TRAX
2 Dec 2015
France
Avelia, not Avelia Stream.
The Amtrak Acela is the Avelia Liberty, the TGV M is the Avelia Horizon.
Citybreak1
14 Mar 2022
No double decker trains either.
Any ideas what Eurostar will order yet?
It will be a lot of trains to Paris Brussels and Amsterdam will they all run full?
Sorcerer
20 May 2022
I just went down the route of fast Alstom in a similar way to the 395/895s and 397/897s.
Not an unreasonable approach actually. Trains in the 8xx range are next-gen high-speed express units, so a New Pendolino could very well be classed in a way where we get 390/890, or it could be 390/391 in the same way Eurostar's stock is 373/374, though I'd consider that quite unlikely since its' not the same operator. The potential stock is arguably more related to the current Pendolinos than the 895s will be to the 395s, so no reason it couldn't be an 890 though.
Forgot about that bit, unless they take them via road to Temple Mills probably not then.
None of the related continental trains have any UK supply chain, and 12x8-car units is hardly enough to invest in new build facilities.
Anyway, it's not going to happen unless Virgin gets approval for paths and maintenance slots.
There are two other potential operators, no doubt with their own rolling stock plans.
StephenHunter
22 Jul 2017
Weirdly enough, we did manage to get CIWL carriages built here down the ECML in the Victorian and Edwardian era to a port... but removing the running boards on the side.
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
Still no Germany or southern France :rolleyes:. If it wasn't obvious enough it was just going after E* it is now. Hopefully we'll have better spacing for Amsterdam and, if I really want to push the boat out, some stops in Kent!
As of yesterday (19/8/25), International Railway Journal now has an article titled Virgin sets out details of plans to launch Channel Tunnel train services in 2030, which includes the following:
Virgin said it was also ‘exploring‘ a four-voltage option that would add 15 kV 16·7 Hz networks for use in Germany and Switzerland, subject to ensuring that the delivery programme remained unchanged.
and
The group added that it had ‘ambitions to expand further across France, and into Germany and Switzerland’, and would ‘continue to explore ways to bring services back to Kent and to enhance onward connectivity to the wider UK rail network.’ Le Train said it saw opportunities to co-operate to offer a ‘compelling product’ on routes to southwest France.
Trainbike46
18 Sep 2021
belfast
and
Vague ambitions are nice, but I have more faith in Eurostar's vague ambitions for Switzerland and Germany than in Virgin's for Switzerland, South of France, or Germany!
(and Yes, I don't consider what either is offering more than vague ambitions at this stage)
(though I guess vague ambitions is better than nothing)
TheWierdOne
30 Oct 2020
and
Interesting that they mention consulting the infrastructure managers in Europe. One had to think that they’ve been given a fairly strong positive indication from all parties to get this far. If SNCF Réseau had turned around and said « jog on Branson » they wouldn’t be bothering signing for trains with Alstom. Their stabling and pathing requirements on the continent are hardly earth shattering so it’s possible they’ve been told by one party or another to get UK depot access before lodging formal requests on the Europe side.
43102EMR
28 Mar 2021
Indeed - appreciate most of the key bits need to be sorted out now, but it does seem that Virgin thinks it’s guaranteed they’ll be offered paths by the ORR when they’re up against the likes of Trenitalia who have much more experience and proven stock with operating international services. That being said, I guess it’s a “wait and see” scenario to see whether they’re actually offered…
Sorcerer
20 May 2022
I think Virgin are being a bit too ambitious considering that they haven't even got any paths for the three capitals route they're after and might not even get them at all. I think Eurostar are probably more likely to get into those markets first, and maybe I'd even go as far as to say that Trenitalia would be more likely to get their London to Milan services. I would love to see a return of Virgin Trains, but we need realistic expectations first and foremost.
Part of me thinks there's a chance Virgin will try to legally challenge any decision to award the paths to Trenitalia if that ever happened. :lol:
Trainbike46
18 Sep 2021
belfast
The issue is Depot access, not paths, is it not? To a lesser extend St Pancras capacity is the other limiting factor. Though potentially a plan that requires less or no depot space in the UK would have a better chance.
Virgin sounded confident they'd get WCML paths too, though they didn't get those (and frankly, were never going to with the amount of paths they requested)
Sorcerer
20 May 2022
You're right, it is technically a competition for depot access rather than paths, and to some extent capacity at St. Pancras. But even so it seems Virgin are very confident in their chances, and unlike the WCML open access there's also a realistic chance of it happening. But they are up against Trenitalia who have already made a success in the open-access European high-speed market and will have a much easier time with their rolling stock procurement, so I'd think it wise for them to focus on getting any of the three capitals route before thinking about Germany or Switzerland. I think even Amsterdam is a bit ambitious.
43102EMR
28 Mar 2021
Yes, more what I was getting at from a pathing perspective, St Pancras being the main issue on that front. I do agree though that Temple Mills space will be the deciding factor, but in the end I can still see it going to Trenitalia for the reasons I highlighted above, not to mention your point about the WCML paths they previously applied for.
vuzzeho
11 Apr 2022
Genuine question - what's stopping one from going 'fine then, I'll build a depot myself' or what's stopping Trenitalia/Virgin from just using a depot in France?
Several years planning, development and construction, plus a couple of hundred million pounds. Temple Mills was £400m 20 years ago, although that was on the expensive side.
Amalie
5 Feb 2023
The Netherlands
I’m not familiar with logistical reasons why space in Temple Mills would be essential, but I’m sure there are reasons why.
Regardless of where the depot is, it
also needs to be a secure enough depot too, meeting the standards of the British, and other countries where the train would operate in.
That is to say that while they can (and also probably would need to) use a depot outside England, it can’t just be any random one in France/Belgium/The Netherlands either.
TheWierdOne
30 Oct 2020
also needs to be a secure enough depot too, meeting the standards of the British, and other countries where the train would operate in..
This is a big one that I think flies under the radar, from chatter in previous threads on Eurostar, I think cross channel trains have to be stored securely, particularly on the European side to prevent someone sneaking aboard and illegally crossing between the UK and Schengen of vice versa.
Le Landy depot in Paris where the Eurostars are maintained, is part of a larger complex that maintains TGVs and other SNCF rolling stock. I don’t know the answer, but are there any special arrangements there? (Other than the longer depot shed).
