Egg Centric
With the Ordsall chord it's reasonably easy, if somewhat silly, for a service to run from Manchester Victoria to London Victoria or vice versa. Has this ever happened on a charter?
Surely the addition of the Ordsall Chord doesn't change too much about theoretical special workings, since you could go via Denton.With the Ordsall chord it's reasonably easy,
Or likewise Manchester Victoria to Southend Victoria, that would be reasonable too.for a service to run from Manchester Victoria to London Victoria or vice versa.
Via Philips Park West Junction, Baguley Fold Junction, Ashton Moss North Junction and Denton Junction.How would you get from Manchester Victoria to Denton without the Ordsall Chord and without reversing?
Quite easily, regular occurrence on ECS movesHow would you get from Manchester Victoria to Denton without the Ordsall Chord and without reversing?
This was a regular route for passenger trains in the 1980s. I think it started when the Nottingham-Glasgow and return were diverted off the Settle and Carlisle to run via Manchester in 1982.Philips Park West Junction, Baguley Fold Junction, Ashton Moss North Junction and Denton Junction.
Up to the closure of the Great Central London Extension trains between Sheffield Victoria and Nottingham Victoria were common. But Great Central trains running through to/from Manchester used London Road/Piccadilly and Central.In times past the train could have passed through Sheffield Victoria and Nottingham Victoria en route.
Of course to avoid reversing it would be London-Manchester-Southend or vv.I'll take you guys words for it for various routes, not being an expert on this sort of thing
Oooooh even better - a "Three Victorias" service. Or maybe there's even more?
Am interested in whether this has occurred (or is planned to) rather than theoretical possibilities mind.
These went Romiley-This was a regular route for passenger trains in the 1980s. I think it started when the Nottingham-Glasgow and return were diverted off the Settle and Carlisle to run via Manchester in 1982.
The absence of intermediate times in the WTT between Romiley and Ashburys means that the services were booked via Reddish, not via Guide Bridge.Crowthorn Junction to Guide Bridge (closed circa 1980s)
Likewise, and not all that recently either, that was the last time I went over the line although I should be going Stockport-Stalybridge for the first time since then next Saturday on a Crewe-Edinburgh day out.More recently, I travelled on the slightly unusual route via Denton, this on a diverted Manchester Victoria->Buxton working, on a Sunday afternoon sometime in the 2000s when most of the line between Manchester Piccadilly and Stockport was closed for engineering work.
I mean, they could head via Richmond and Barking using the District line through Victoria...Of course to avoid reversing it would be London-Manchester-Southend or vv.
Yes I think you are right here. I had forgotten that trains only went via Stockport after the Hazel Grove chord opened.These went Romiley-Guide Bridge orReddish -Ashburys-Philips Park-Manchester Victoria. Until the Hazel Grove Chord opened in 1986
I definitely remember taking this route from Manchester Victoria in the mid 1980’s as far as Nottingham. I think the destination was Harwich Parkeston Quay and it originated further north, quite possibly in Scotland. It was a named service, “North West Dane” or similar?This was a regular route for passenger trains in the 1980s. I think it started when the Nottingham-Glasgow and return were diverted off the Settle and Carlisle to run via Manchester in 1982.
No connection to the District at Olympia though. You'd need to keep going to Clapham, then go around the Kingston Loop and join the District line at Wimbledon!But then they'd still have to reverse at Barking to get to Southend Victoria. Plus I don't believe there's any way to get from National Rail onto the District Line tracks at Richmond.
EDIT: I believe there is a solution: You could get on to the Victoria District Line tracks via the WCML then Kensington Olympia, then do a complete circle of the Circle line to get back to Earls Court and Kensington Olympia, then use the North London line to get to Stratford, then on to Southend Victoria(And do I really have nothing better to do on a Sunday morning than work that out...)
The European -It was still running in early 87.I definitely remember taking this route from Manchester Victoria in the mid 1980’s as far as Nottingham. I think the destination was Harwich Parkeston Quay and it originated further north, quite possibly in Scotland. It was a named service, “North West Dane” or similar?
Here’s how to do the Manchester - London - Southend service (I THINK):
Manchester - Willesden (WCML)
Willesden - Clapham (WLL)
Clapham - Richmond via Kingston (SW lines)
Richmond - Richmond via the circle line and Victoria (LUL)
Richmond - Clapham via Kingston (SW lines)
Clapham - Willesden (WLL)
Willesden - Stratford (NLL)
Stratford - Southend (GEML)
There was also (briefly) a North West Dane. Think that once the European was rerouted via not quite London, its sprinter replacement (150 all the way from Harwich to Liverpool) became either the Loreley or the Rhinelander.The European -It was still running in early 87.
Oh right. So maybe then…If my reading of Google maps is correct, that won't work because there's no connection between SWR and the District Line/Overground at Richmond. Since as @greatkingrat pointed out, there's no connection at Olympia either, it looks to me like so the only place you can join the District Line is at Wimbledon.
I'm also not entirely clear whether you can get directly from Olympia to the SWR mainline towards Wimbledon at Clapham Junction to do your Richmond via Kingston bit - my eyes failed me trying to decipher the maze of points and crossings at Clapham Junction on Google maps: But you can certainly do it going via Putney and then (ironically) the District line to Wimbledon, before you hit the problem at Richmond![]()
It also didn't use the WCML at the London end, going out via Reading and Oxford instead. (I didn't even realise you could access the GWR from Olympia, but hey, you learn something every day!)
