Very Curious RTT Entry 30.09.25
Deepgreen
12 Jun 2013
Gomshall, Surrey
This has caught my eye for tomorrow - described as pathed as a High Speed Train at 125mph, from Woking via North Downs line to Redhill, Tonbridge and on down through Kent to Ashford and reverse back round to Woking via Maidstone and Clapham Junction. Is the timing an error, I wonder, as I don't see many opportunities to do that speed!
trainmania100
8 Nov 2015
Newhaven
73s test train. Should be:
73963 GBNR WOKINGUSG WOKINGUSG L N
73964 GBNR WOKINGUSG WOKINGUSG L N
Northampton
I'd imagine that's the NMT. It's a HST, and it's allowed to run at up to 125mph so that's the correct timing load.
EDIT: Just checked the Service Code and that maps to the Video Inspection Unit.
52495119
42​
ColasNetwork Rail – Video Inspection Unit, Class 153 (DMU) 2Qxx
So either they've got the wrong TSC (always possible) or somebody's copied a path and not double-checked all of the data because 1Zxx is usually used for test trains when transiting (not recording).
Class 466
5 Mar 2010
Atherton, UK
Might encounter some clearance issues if it was a HST - timing load does not equal allocated traction
Deepgreen
12 Jun 2013
Gomshall, Surrey
Thanks to both - the 1Z73 headccode immediately made me think of 73s, but I also latched onto the NMT. I shall have to pop out to see!
Northampton
Very true on both points! However test trains other than the NMT would usually be timed as something else to reflect the fact they don't have a HST's performance or top speed.
It says it's a STP path but doesn't have the 'set up by' bit so not sure quite what's gone on there. If it is VSTP that does go some way to explain the odd timing load.
Freightmaster
Verified Rep
7 Jul 2009
Just to clarify, this working is a driver training run for Colas IM traincrew using PLPR-2
which would normally be stabled at Woking all day on a Tuesday.
There is a similar working on Wednesday too:
MARK
Northampton
it's not VSTP - it says Great Britain (Network Rail, TPS), so it came through the usual planning process.
Thanks for the confirmation, I thought that was the case but was expecting the publication date, which I was sure RTT at least used to show but maybe doesn't now? (It's not something I'm normally looking at).
Deepgreen
12 Jun 2013
Gomshall, Surrey
MARK
Many thanks - not just clarifying, but answering the question, along with 'Trainmania100'!
Tom
19 Jan 2008
35,000ft
RTT has never shown publication date, because it is a little ambiguous due to how CIF works.
