brianthegiant
- Joined
- 12 May 2010
- Messages
- 588
Seems fashionable in the medai to criticise Network Rail at the moment, separation into regional units vertically integrated withs TOCs seems to be a popular proposal, but would it make things better or worse? Many think there is a need to reshape NR, but is vertical integration the best solution?
I see a number of issues with vertical integration (VI):
not used in most other transport sectors (airlines dont own airports & ferries dont own ports), why is it needed for railways?
many industires moving away from vertical integration, instead outsourcing more & focusing on core business, eg the smart car plant works more like an industrial estate of component fabricators working together
specialised equipment like test trains, FMUs etc, would have to be either divided up or put into ROSCO hands, would be more difficult to rapidly deploy.
specialist engineering skills would be divided up or outsourced, would be more difficult to strategically deploy in different regions according to demands & projects
smaller regional bodies would be less resourced to run cutting edge projects like ERTMS trial for example
would TOCs operate network any better, some are better than others, some fall foul of commercial pressures, but in general the expertise of TOCs is focused on tickets sales and stock operation, would they prioritise track/signals upgrades renewals enough?
Possible Conflicts between competing TOCs & freight operators..
Do stagecoach want VI just so they can prioritise their movements over eg cross country?
