Valid routes Didcot to Weymouth?
Pete81E
2 Dec 2012
Hi,
Thinking of taking the train to Weymouth for the day during half-term so say 1st November.
Could someone tell me if an off-peak day return is valid via both Bristol and Basingstoke/Reading to enable a bit of a circular day tour? Or would the journeys need to be booked as specific singles out via one route and back via another?
Thanks in Advance,
Pete
soil
28 May 2012
The £50 CDR route 'Via Basingstoke' is not valid via Bristol. It's valid via Basingstoke, Reading & Southampton.
The £50.50 CDR route 'Via Westbury' is not valid via Bristol you can travel Didcot - Swindon - (optionally via Bath -) Westbury - Castle Cary - Weymouth, or Didcot - Reading - Westbury - Castle Cary - Weymouth.
You should be able to use the £50.50 CDR via Basingstoke also.
Note that a Didcot - Swindon CDR is £10.30, and a Swindon - Weymouth via Yeovil CDR is £16 (this is cheaper than Westbury - Weymouth via Yeovil!).
This combination of tickets would be valid Didcot - Bristol Parkway (direct) - Weymouth, or Didcot - Swindon - (optionally via Bath -) Westbury - Weymouth
You obviously could not travel via Reading on this combination.
maniacmartin
Fares Advisor
15 May 2012
Croydon
Looking at the mapped routes, with a hypothetical ANY PERMITTED ticket, you can go:
BL+WE - Didcot - Reading - Westbury - Castle Cary - Weymouth
MW - Didcot - Reading - Basingstoke - Southampton - Weymouth
MW+WE - Didcot - Swindon - Chippenham - Westbury - (Bath Spa optional) - Castle Cary - Weymouth
None of these routes allows travel via Bristol.
If you want to go out by one route and back by another, you can buy a return for the cheapest route, then get a change of route excess for one portion only, which costs half the difference between the cost of both return tickets.
John @ home
1 Mar 2008
There are separate Didcot to Weymouth return tickets:
via Basingstoke
Off-Peak Day Return £50.00 (Railcard £33.00) (M-F not before 0900)
Anytime Day Return £53.00 (Railcard £35.00).
via Westbury
Super Off-Peak Return £50.50 (Railcard £33.35) (M-F not before 1030)
Off-Peak Return £64.00 (Railcard £42.25) (M-F not before 0850)
Anytime Return £156.00 (Railcard £102.95).
To travel outward by one route and return by the other, buy a ticket for the less expensive route and prior to travel buy an excess fare at the booking office. It costs half the difference to travel by a more expensive route in one direction only.
Pete81E
2 Dec 2012
Thanks for the replies. I think I'll probably check the weather first and drive to Swindon for the 09:31 and go via Bath/Westbury. Much the cheapest option! Basingstoke can wait...
Ebeneezer Pete
D6975
26 Nov 2009
Bristol
I like the 'Bath Spa optional' bit.
Try going that route (Chippenham-Westbury) without going via Bath Spa, you'll find your options rather limited.:lol:
soil
28 May 2012
two trains a day.
