Mcr Warrior
- Joined
- 8 Jan 2009
- Messages
- 17,333
Recently acquired a copy of "The End of the Woodhead Route: Electric Trains Stop Here" by Stephen Heginbotham (Amberley Publishing - 2020).
The book talks about a sand-drag siding located near to Valehouse Signal Box and used for runaway trains coming down from Woodhead tunnel.
Apparently loose-coupled freight trains were forbidden from using the route when Valehouse Signal Box was locked out of use.
Furthermore, should a runaway have occured, the driver of the train would be required to sound short blasts on the whistle/horn all the way down from Woodhead, and the Woodhead Signalman (five miles back up the line) or the Torside Signalman (one and a half miles back from Valehouse Signal Box towards Woodhead), or both, would comply with a special instruction and send a 5-5-4 bell signal to the Valehouse Signalman, who would set his points for the Valehouse sand-drag.
A handful of questions. At what point might a driver realise that his train (or part of his train) was a runaway?
Are we talking about brake fade / failure, and/or some alarm sounding in the cab that the train was no longer intact / automatic application of continuous brakes?
If there was a split in the train on a downhill stretch, couldn't the two portions of the train have been brought to a halt by gradual application of the brakes by the driver (as the relative speeds between the two portions of the train on the downhill section would be relatively small), or is the issue that the engine end of the train might initially speed away, before the loose portion catches up and crashes into the rear?
And what purpose did brake vans (if actually used in recent times) serve to prevent accidents, and when would they have last been used on the Woodhead Route?
