Using a 80 Year Old Clockwork Train Set
eastwestdivide
17 Aug 2009
S Yorks, usually
Great to see it being used, instead of stuck in a display cabinet.
And they way those things hold the corners at high speed is quite something!
gavinjustice
3 Sep 2011
It has been sitting in a loft for quite a while. Started off a bit slow but needed wound up so spent a while looking for the key.
Engineer
7 Jan 2010
Thames Valley
Lucky you. They made this model with a grey coal truck and the same brake van into the 1950's. Get that 3 in 1 oil out and put some lubrication on the gears and clockwork spring, before the winding up friction snaps it.
