JakeMurphy
- Joined
- 30 Aug 2018
- Messages
- 1,234
390049 is currently doing 1S48 to GlasgowIs 221115, 221112, 390049 or 390123 out about today please?
Thank you.![]()
Thank you.![]()
Thanks390049 is currently doing 1S48 to Glasgow
Anyone know this service and whether it will run?
Realtime Trains - 0Z62 1500 Cambridge to Harringay Up Rev Sdgs
Realtime Trains provides live realtime running information for the Great British railway network using open data.www.realtimetrains.co.uk
Thanks![]()
| 390049 | |||
| EdgeHlDHS | 04+13 | 5R05 | |
| Lime St | 04+24 | 05:26 | 1R05 |
| Euston | 08:09 | ||
| Euston | 08:54 | 1S48 | |
| Glas Cen. | 14:03 | 14:34 | 1M15 |
| Euston | 19:49 | 20:22 | 9G45 |
| New St. | 22.05 | 22.08 | 9G45 |
| Wolvrhptn | 22.28 | 22+45 | 5G45 |
| Oxley CMD | 22+52 | ||
| 390123 | |||
| LongstCMD | 07+36 | 5A12 | |
| ManchstrP | 07+48 | 08:05 | 1A12 |
| Euston | 10:40 | 11:50 | 1F16 |
| Lime St | 14.19 | 14.47 | 1A45 |
| Euston | 17:19 | 18:15 | 1S95 |
| Glas Cen. | 23:09 | 23+29 | 5S95 |
| PoldieCMD | 23+40 | ||
| 221115 | |||
| BrtnUNCmd | 04+37 | 5P38 | |
| New St. | 05+09 | 05:30 | 1P38 |
| BlckpoolN | 07:32 | 07:54 | 9M48 |
| New St. | 10:04 | 10:10 | 9M48 |
| Euston | 11:55 | 13:21 | 9G77 |
| New St. | 15:06 | 15:28 | 9G77 |
| Wolvrhptn | 15:47 | 15+55 | 5G77 |
| Oxley CMD | 16+03 | 17+28 | 5B84 |
| Wolvrhptn | 17+35 | 17:45 | 1B84 |
| New St. | 18:05 | 18:15 | 1B84 |
| Euston | 19:57 | 20:49 | 9G46 |
| New St. | 22:29 | 22+58 | 5D46 |
| BrtnUNCmd | 23+44 | ||
Thank you very much @Triumph
390049 EdgeHlDHS 04+13 5R05 Lime St 04+24 05:26 1R05 Euston 08:09 Euston 08:54 1S48 Glas Cen. 14:03 14:34 1M15 Euston 19:49 20:22 9G45 New St. 22.05 22.08 9G45 Wolvrhptn 22.28 22+45 5G45 Oxley CMD 22+52
390123 LongstCMD 07+36 5A12 ManchstrP 07+48 08:05 1A12 Euston 10:40 11:50 1F16 Lime St 14.19 14.47 1A45 Euston 17:19 18:15 1S95 Glas Cen. 23:09 23+29 5S95 PoldieCMD 23+40
221115 BrtnUNCmd 04+37 5P38 New St. 05+09 05:30 1P38 BlckpoolN 07:32 07:54 9M48 New St. 10:04 10:10 9M48 Euston 11:55 13:21 9G77 New St. 15:06 15:28 9G77 Wolvrhptn 15:47 15+55 5G77 Oxley CMD 16+03 17+28 5B84 Wolvrhptn 17+35 17:45 1B84 New St. 18:05 18:15 1B84 Euston 19:57 20:49 9G46 New St. 22:29 22+58 5D46 BrtnUNCmd 23+44
Isn’t that the one that had the seized axle at Lockerbie? It won’t be out for while I would thinkMorning, can anybody advise if 390138 is out today please?
Thanks in advance
221115 was on 9M48 from Blackpool North with 221116. Arrived EUS 1155 (well 51 as it was 4 early).Does anyone know where 221115 is? It was said to be on 9G77 1321 from Eus to Wolverhampton but it wasn't, it was a red voyager instead of 115.
Thanks for any details.![]()
Went to Wembley, coming back out late to work 9S93221115 was on 9M48 from Blackpool North with 221116. Arrived EUS 1155 (well 51 as it was 4 early).
Can't currently see where it went from there though.
Thank you very much to you both for those details.Went to Wembley, coming back out late to work 9S93
Hi, could anyone find out what's on https://www.realtimetrains.co.uk/train/H58118/2021-02-10/detailed & https://www.realtimetrains.co.uk/train/H07992/2021-02-10/detailed#allox_id=0 please?
Apologies, I was in a bit of a rush so missed that. All good as I still caught 6Y42. Missed 610T though but I saw the last few DB Schenker wagons rolling past6Y42 is 66763 (it does say on the link if you click on ‘show train information’.
Hello, does anyone know what's on this: Realtime Trains - 2P51 0725 Exeter St Davids to Plymouth
Thanks.
Thanks.802009
Seems to be running wrong line towards Teignmouth been heavily delayed in Dawlish area or may even be the broken down train that’s causing delays.Thanks.
Correct, it's failed at DWL. 3 AUX reset attempted but failed, does anyone know what's also on Realtime Trains - 1C69 0637 London Paddington to Penzance.Seems to be running wrong line towards Teignmouth been heavily delayed in Dawlish area or may even be the broken down train that’s causing delays.
Ah what’s it doing wrong line? just watched 1C69 pass Dawlish cams..no number thoughCorrect, it's failed at DWL. 3 AUX reset attempted but failed, does anyone know what's also on Realtime Trains - 1C69 0637 London Paddington to Penzance.
Looks like it let 1A73 pass, it's now on 5P51 ECS to Laira. So it looks like the fitters have fixed it.Ah what’s it doing wrong line? just watched 1C69 pass Dawlish cams..no number though
800320Correct, it's failed at DWL. 3 AUX reset attempted but failed, does anyone know what's also on Realtime Trains - 1C69 0637 London Paddington to Penzance.
Colas light engine (possibly 70816) being sent down to assist with engineering works out of Westbury this weekend. Headcode will be 0C23.https://www.realtimetrains.co.uk/train/R05102/2021-02-12/detailed Anyone know? Its a bit of a strange working
Hello,
Does anyone know where 1Q18 06:08 Reading Triangle Sidings to Paignton current location is. As RTT's data feeds are down, the last position reported was TVP at 08:10.. Any help is much appreciated.
Alright, thanks for the help. The signal the mast is damaging is DM203A between Starcross and Dawlish Warren, signal is leaning towards the track and the top aspect is damaged. The boat is still hitting the sea wall, down main is shut until further notice. Dawlish has had issues non-stop this week, from a broken 802 early yesterday morning..Feeds aren't down, it's still in the loop, Dawlish blocked until at least 10:00 due to high seas.
There's also the added complication of a yacht being pushed up against the sea wall and it's mast damaging a signal.
