Upgrading an Off Peak return to Anytime where SOR doesn't exist
radamfi
29 Oct 2009
radamfi
29 Oct 2009
what's the jouney?
No particular journey in mind, but an example would be Didcot Parkway to London.
Off Peak Return exists at £22.30 but there is no month validity Anytime equivalent.
If you upgrade a ticket type, the whole ticket is supposed to be excessed, not just one portion. So for same-day travel between Didcot and London the excess would be SDR (£46.70) - SVR (£22.30) = £24.40, however this excess costs more than the cost of an SDS at £24.00 therefore it is cheaper for you to buy a new ticket, and not use the rtn portion of the SVR. If you are travelling back a different day, that excess could not be cheaper, and given that it is higher than a new ticket, then the fact there isn't an excess doesn't really matter, as a new ticket is cheaper anyway.
Excesses are a lottery, so what would happen in reality could be quite different!
radamfi
29 Oct 2009
The scenario I am thinking is being caught on the train using the return portion. My guess is that you get charged the difference between 2 x SDS and the SVR.
No, because that is more than the cost of one SDS!
It should not be cheaper to not have a ticket than to have a ticket:!:, and indeed the rules of excessing say that if a new ticket is cheaper than an excess then that should be issued instead. The cheapest option should be offered.
radamfi
29 Oct 2009
If that is the case, then it is always worth buying a SVR at all times as it would be cheaper than two singles if you are returning a different day.
Better value, yes, but not cheaper - at least, not cheaper for a one-off journey.
An Off Peak Day Single from Didcot to London is £19.90 and valid on the 0915 from Didcot, arriving 1009. An Anytime Day Single back is £24.00, the total is therefore £43.90.
However the Off Peak Return doesn't let you get into Paddington until the 1037 arrival (0953 from Didcot), and costs £2.40 more.
However for £2.40 more, you do get a return portion you can use another time, so it is better value to do that.
