Unusual technological nostalgia
shawmat
15 May 2020
Maidenhead
The Lotus 123 spreadsheet. To be honest, I've forgotten the exact commands but it was something like /fo to open a file, /fs to save it. Just like people could briefly write texts at super-human speeds, so you could drive a spreadsheet without waiting for the previous command to complete.
xotGD
4 Feb 2017
Five-and-a-quarter inch floppies and three-and-a-half inch 'stiffies'.
The pneumatic tube systems you used to see in some department stores for sending cash from the tills to the cash office.
The choke in a car.
ABB125
23 Jul 2016
University of Birmingham
I also like T8 florescent tubes, though I'm not sure why! They're also quite efficient, around 90lm/W; most built-in LED fixtures are around 100lm/W, whilst "LED tubes" can often be less efficient that the fluorescent tubes they're meant to replace. Although some fluorescent light energy is wasted through the ballast (and I think I read somewhere that the ballast can use up to the same amount of power again as the tube itself).
Having said that, I'm also a big fan of LEDs: recently I managed to persuade my dad to upgrade the lighting in his garage; we went from an ancient* 2x6ft T8 fitting and two modern 4ft T5 fittings to four beautiful 60W/7200lm LED fittings. I'm not exaggerating, it's as bright as daylight in there now!
*So old, it was made in West Germany. Apparently the fitting came from my granddad's workshop (presumably when he retired), but my granddad bought it second hand! So it could easily be 50 years old!
birchesgreen
18 Aug 2015
Solihull
Ah yes manual chokes, my first car (a Lada) has one. Though none of the cars i had driven when i was learning had manual chokes... luckily i managed to figure it out pretty quickly so i could drive home!
D365
29 Jun 2012
I've been using my EHIC card for this purpose. It's been nowhere this year and as of Jan 1st it'll likely be useless for anything else.
Oh goodness, don't remind me :frown:
The traditional flourescent tube is a good source of light, but very fiddly to replace. Rigmarole of checking whether the ballast or the tube has gone, trying to insert the thing etc.
I do miss the clickety clack of solari boards as others on here.
SuspectUsual
11 Jul 2018
Very low tech: does anybody still use old credit cards to clean ice off the windscreen? Or at least similarly shaped plastic cards that don’t give away bank details. I remember the near derision that would be directed at anyone who bought a proper windscreen ice-scraper.
Hotel loyalty cards for me
And also, variously:
- what I believe was known as a “trimphone”, the narrow first generation button-push phones
- Atari games console complete with wood effect finish
- Sony Walkman (although i don’t miss cassettes). I had one that actually had a rewind button, many of them didn’t at first. The height of cool and luxury
xotGD
4 Feb 2017
Thought of another one: The Banda Machines they used to have in schools for making copies of worksheets, etc.
GusB
Elginshire
When we first had a landline, it was an old 700-series telephone that was hardwired to the wall in the kitchen. When it eventually went on the blink, it was replaced with a similar model, but the BT engineer installed the then new-fangled sockets and an extension which meant we could move it into the hall - I've also had many conversations while sitting on the stairs! The phones were rented rather than bought in those days.
Somewhere I have a recording of the ringing sound which I used on my mobile for many years, and it used to generate a few comments.
SuspectUsual
11 Jul 2018
Yes, this! Argos in Cov used to have one, as a little ‘un I was absolutely enthralled by it
nlogax
Mostly Glasgow-ish. Mostly.
Just thought of another one; those huge black security cameras hovering overhead in 1980s stores (C&A and Woolies are ones that stick in the mind). Menacing rotating hemispheres of doom containing what turned out to be terrible quality cctv cameras.
1970s Photo-Scan CCTV Unit
birchesgreen
18 Aug 2015
Solihull
I have a couple of fluorescent tube lights (to be honest half the stuff mentioned in this thread i have in this house, i feel like i live in a museum!) I had to change the bulb last week in one of them, quite a palaver until i remembered that i need to bend one of the metal prongs with a pair of pliers first so it fits!
There's a blast from the past. Haven't seen one in years !!
61653 HTAFC
18 Dec 2012
According to Futurama, they'll still be in use in the 31st century... :lol:
A possibly apocryphal tale about those systems comes from my cousin who as a teenager worked in a Virgin Megastore. Allegedly during quiet times the staff would amuse themselves by er... "floating an air-biscuit" into one of the capsules and then sending said capsule upstairs to the gaming dept. :lol:
Ianno87
3 May 2015
Little me used to be fascinated watching them rotate back and forth!
RichT54
6 Jun 2018
When I worked at Heathrow in the 70s there were several pneumatic tube systems (referred to as 'Lamson Tubes' after the manufacturer) that we used to send and receive documents and charts to various parts of the airfield. The main system had smaller carriers that had rotating collars that you could set to indicate a destination address using a combination of letters and digits such as 'B1' which was for the teleprinter section. Quite often the carriers would get jammed in the works, usually because someone hadn't fastened the end cap properly and the contents had come out causing subsequent carriers to get stuck. A workman then had to go around the system to find and clear the blockage, then all of a sudden, half a dozen carriers would fly out of the pipe in rapid succession. Several of the airlines had their own end-to-end systems including B.O.A.C, B.E.A. and Pan Am. - names that have long since vanished!
david1212
9 Apr 2020
Midlands
My first laptop, an NEC with Windows XP, it had pre installed programmes, office for example.
XP was so much more user friendly than any of the later versions, am now on Windows 10 and it's dreadful, also had to pay a fortune for office, which to be honest I rarely use.
I still get the occasional PC running Windows NT4 put in front of me to somehow bring back to life.
As to the laptop I'm using to post this when Win10 came along I swapped to Linux specifically Mint. Libra Office is included while WPS is very good for Powerpoint files.
23 May 2020
Blandford Forum
The choke in a car.
They still have the tube system in some Tescos, although I don't know if they're still used. One system I distinctly remember from my childhood is a cash carrying arrangement in a shop in Acton High Street, where the assistant put money in a little carriage attached to a wire, then used a spring trigger arrangement to fire the carriage along the wire to a central cashier. The cashier would sort out the cash, and place the change in the carriage which would then be pinged back to the assistant. There were several wires crossing the shop ceiling.
Actually, trimphones originally had dials. see here:
EDIT: apologies, I didn't see similar responses which I hadn't seen. But at least there is a picture.
RichT54
6 Jun 2018
I remember back in the 60s, there was a wire system like that in the Plummers department store in Folkestone.
The Jacksons department store in Reading still used a Lamson pneumatic system for handling payments right up until it finally closed at the end 2013.
birchesgreen
18 Aug 2015
Solihull
Gloster
4 Sep 2020
Up the creek
I can remember there being one in one of the stores in Guildford, not Plummers (that was much too modern), and being fascinated by the criss-crossing tubes when they had the ceiling down for some reason. Actually, it may have been a compressed-air system, although I may be mixing up two shops. Made a lovely Whoomph when the container left.
headshot119
31 Dec 2010
Dubai
I wonder if the OP meant the Viscount phone?
That takes me back! A hotel in Devon we used to stay in when I was young had them in every room. All cream coloured, though they had a red one in the reception to call the local taxi firm from.
DB
Guest
18 Nov 2009
I still pine for DOS as an operating system.
Windows still has much of that command line functionality, and in the IT world it's used regularly, along with Powershell, which has evolved from it.
One which I can't understand - cassettes. They seem to have a cult following, but why? The sound quality was never great and gets worse with use. They jam, get chewed, etc. Their only benefit was portability, but digital files now do that much better.
birchesgreen
18 Aug 2015
Solihull
I think the Viscount was one of the first BT phones to support tone dialling (with a switch on the back).
I'm not sure, but I think BT still support pulse dialling.
I assume they do, Virgin do as i can still use my GPO 746.
PeterC
29 Sep 2014
On a railway (and airport) theme - Solari mechanical flip-panel displays.
- used to love the rhythmic click-click-click at major stations as the departure boards updated regularly.
Saved on announcements as it prompted you to look up at the board whenever anything changed.
Ducatist4
29 Apr 2019
Mansfield
I use my Tesco club card but it only gets 20% off.
