Unusual move at Watford Junction 8 Jan
A freind of mine was on 9G46, 2106 Euston - Wolves last night. Although it departed Euston 8 minutes late and fractionally ahead of the down Highlander (1S25), it was evidently held on Camden Bank and the Highlander went first. Most likely because the Highlander had been signalled out early just before the Wolves was ready to go. The Wolves service then lost a further 6 minutes to Harrow behind the Highlander. And then….
….. the Watford workstation signaller held the Highlander in the platform at Watford Junction (not booked to call), and routed the Wolves via the Up Fast to overtake it. I didn’t even know this was possible! It must have been enabled with the alterations when the junction was recommisioned.
Two questions:
1) has any one seen this happen before, with any trains?
2) did the signaller have a mate on the train with a quail and a highlighter?
RTT links here:
9G46 https://www.realtimetrains.co.uk/service/gb-nr:C50029/2025-01-08/detailed#allox_id=0
1S25 https://www.realtimetrains.co.uk/service/gb-nr:P01173/2025-01-08/detailed#allox_id=0
Tilting007
21 Oct 2024
Rugby
Happens every now and then, mainly if there are failures blocking the DF.
Became possible when the North Junction went in and once the Fast to Fast Crossover went in all platforms now bi-di, although the DF only as far as the turnout to the DC lines.
The highlander does see some funky regulation if there is late running…
Kite159
27 Jan 2014
West of Andover
I've seen a London train getting routed via the Down slow platform when the up fast has been unavailable due to a train fault (a 350 having a hissy fit with a door) at the same time as a Tring train getting routed via the up slow platform.
Always good to have flexibility.
moogal
18 Oct 2012
Milton Keynes
I had this a few months ago on an evening LNR Birmingham service that wasn't booked to call at Watford, was quite surprising to see the platform go past on the wrong side!
Efini92
14 Dec 2016
Two questions:
RTT links here:
It’s rare they actually regulate round there, more so using the up fast. I followed the sleeper to rugby the other week.
RGM654
19 Jul 2022
Harrow
I was on a railtour last year (Midland Pullman on 18th October) that picked up from the up fast platform at Watford Jn.
