Unidentified crossing keeper's cottage
Taunton
1 Aug 2013
I read the car registration as KJW745, which is Wolverhampton, so not all that far away.
The nearer car has been described as a Morris 10, which went out of production in 1948, replaced by the quite different Morris Oxford. KJW numbers were issued in Wolverhampton between July 1952 and June 1953, so one or the other of these two points looks incorrect.
LYradial
8 Jun 2024
welsh marches
There are many things about this scene that don’t seem quite right,
why the wicket gates, there are no pavements for pedestrians or any sign that it might see pedestrian traffic.
why the reflective posts by the roadside, I don’t see a hazard.
most level crossing gates have a circular red target in the centre but not here.
we do not know what is behind the photographer, might be a new housing development.
why, at a time when photography was an expensive hobby was the photo taken.
Rescars
25 May 2021
Were red targets used in locations where the gates were protected by signals? Does their absence suggest that there is a signal box just out of shot and the gates are within station limits?
Are we certain the rear car is a Morris? There is something about the boot shape which looks a bit like a Hillman.
I agree that there is probably a road joining from the left immediately after the crossing. The crossing widens significantly towards that corner - the far wicket gate is way out of line - and there is road surface visible between the bars of the gates where it would otherwise be verge.
It's a shame we can't see more of the third car which is hidden by the nearside gate post (apart from its offside rear wing). Is it on the road, or parked (rather unwisely) just beyond a junction?
John Webb
5 Jun 2010
St Albans
I'm beginning to wonder if we're looking at a station that has it's platforms staggered. hence the need for the wicket gates?
The posts with reflectors help to line traffic up with the crossing, particularly in the absence of a kerb and possibly in a snowfall. May also be to deter parking on the verge on the approach to the crossing?
There were several variations in targets - not just round ones. It looks to me, although the gates are some distance away, that in this case they may have been square?
We've established that we're in the post-WW2 era. Photography became much cheaper after the war, particularly when stocks of spare 35mm and other film became available. I was taking my first photos around 1954 when I was eight years old, albeit on 120 size film and with the help of relatives.
Rescars
25 May 2021
A bit of gentle googling tells me that my post #63 isn't quite right. The BoT required targets in all instances to be displayed to road users when the gates were across the carriageway, though they weren't needed to warn trains if the crossing was signal protected. The same source suggests that square targets were standard practice on the NER.
LYradial
8 Jun 2024
welsh marches
Squad targets standard on the NER, and possibly the LNER?
pure speculation but I am leaning towards the old midland and great northern joint, and possibly a connection with the vastly increased road traffic for the airfields in east anglia needing a new crossing to be created
added but was not a lot of the joint line single track
Nottingham59
10 Dec 2019
Are/were there many crossing keeper's cottages next to stations?
Are we sure it's a crossing keeper's cottage? It could be part of a station building of some sort.
The home semaphore signal suggests there's a signal box nearby: how far from a box can a mechanically operated signal be located? I'm struck by looking at the North Staffs line from Stoke to Willington how many level crossings in the countryside have little signal boxes and not crossing keepers cottages. The cottages - or at least those remaining - tend to be in or near built up areas where there are several crossings or a closed station nearby. Where presumably the signal boxes were.
If it was added as a wartime measure it wouldn’t have had a relatively elaborate cottage.
Many crossings had non-block signals worked by the keeper from a ground frame. Often there were just distance with the target on the gate serving as the stop signal, but poor sighting could explain the stop signal.
BrianW
22 Mar 2017
Mow Cop- http://www.mowcop.info/htm/thumbs/tn039.htm
Staggered platforms; no signal; no telegraph pole; no 'targets'??
Gloster
4 Sep 2020
Up the creek
The problem is that having similar bargeboards is not enough as this general style was used by a number of railways: they need to be identical. If they are identical then it might be the actual cottage or another one of a batch that were put up by the same company or contractor. The nearest I have found to the original photo, although not identical, was the Great Northern Railway which used a number of such styles. However, that merely makes me think that the GNR is the best railway to start with if someone wants to do an exhaustive search, although I don’t know how that could be done.
Mcr Warrior
8 Jan 2009
If it is Combridge Crossing, which would have been the next nearest stations, up and down the section of line?
WesternLancer
12 Apr 2019
This looks like it. Rocester, Staffordshire.
Ridge tiles don't match...
The original pic (early post war) shows the ridge as plain tiled - no fancy tiles along the ridge with decorative tops. The Staffs past track image (dated 1953) shows old ridge tiles with fancy ridge pattern, albeit some broken - so you would expect them to have been there c1950 for example, and they aren't
the modern google street view image has plan modern ridge tiles suggesting the ridge has been re-tiled since the staff past track image was taken.
So sadly I'm a bit sceptical...
Shrewbly
21 Jan 2017
And also Combridge crossing house appears to be on the wrong side of the road.
Tazilly
14 Aug 2022
Hereford
Having looked at it again there’s only a superficial resemblance. The details don’t match do they. Sorry.
peteb
30 Mar 2011
It certainly is a LNWR design crossing cottage. There were several crossings between Northampton and Market Harborough: Broughton, Stratton, Pitsford and Draughton all spring to mind but I can't find photos on the internet that match entirely: the crossings are skewed or the cottage is the wrong way round. The photo at Harborough is very similar but from memory the area near that crossing was always more built up.
stuving
26 Jan 2017
WesternLancer
12 Apr 2019
stuving
26 Jan 2017
I fancy Lamport station crossing. There is a small building shown on the station side in this 1958 map (1:10,560 NLS), but it's gone by 1969. There is a signal box immediately off the picture on the other side. Whether you think it would be visible depends on how you understand the area marked off at the edge of the road: if it's the grass with reflector posts on it then there's room.
You could try contacting the Northampton & Lamport Railway - someone there should know a lot about the line and any pictures of it.
stuving
26 Jan 2017
That's Boughton crossing, a bit less than a mile south of the station. And when I went to look there, guess what I found still there!
I should add that this is not the one in the OP's picture, it's another clone. The road at Boughton is highly skewed, which is just visible in the Pinterest picture but concealed by foreshortening.
Grumpy Git
13 Oct 2019
As others have already identified, it does look remarkably like crossing cottages on the Stoke-Derby line (especially the barge-boards), although the one in the photograph does not have the decorative (darker) diagonal brickwork detail.
Big Jumby 74
12 Feb 2022
Looking again at the original image, it looks like the crossing is quite skewed, as in some way off being at right angles with the road. The nearest gate post on the left is the wicket gate post, the crossing gate post being further behind, and (to my eye) more distant than its opposite number on the right (by the cottage). This would also explain the apparent angle (skewed) of the left hand gate. This is not apparent if just looking at the right hand gate in isolation. Still doesn't help to identify the actual place though :s - Doing a google earth along many lines (open and closed) in the area, I think too much has changed over the years to make this identifiable via that method?
Further edit: having said above, the signal arm would seem to suggest the rail/road angle is nearer to right angles. Deceptive!
Leigh? 'Uttoxeter Branch'
I noticed this on Google a short while before you mentioned it, but had dismissed it for some reason. Have just taken a closer look, the road/rail angle is about that which I was trying to get at above (a slight skew), and zooming in close there are remnants of building foundations in the undergrowth (where the cottage would have been if this were the original picture location). Next to said foundations and beside the track there is also a brick foundation remnant that could have been the base for a signal post. What do others think? This is Leigh Crossing (west of Uttoxeter) on Dodsleigh Lane. The fencing doesn't necessarily match, but it has been a few years since the original picture was taken!
eastdyke
25 Jan 2010
East Midlands
Here is an undated picture of Lamport station [from ebay]. It has the signal!
http://tiny.cc/43ipzz
And, I believe the station building is shown in this circa 2002 picture [also from ebay]
http://tiny.cc/x3ipzz
And one from facebook stated 1953, there seems to be a small building at the far end of the platform:
