Ulverston to Nottingham?
At £80.50 that ticket is a rip-off!
Next time consider Nottingham-Sheffield (£16.80) and Sheffield-Ulveston (£44.10 "Off Peak" but valid on any train), saving 25% (£20) and valid on exactly the same trains and at any time!
And yeah you can break your journey or cut it short.
Then why the need for an Open Return? (now known as Anytime)? An Off Peak would suffice. Or does she travel back at peak time?
WillPS
18 Nov 2008
She Normally Travels back in the Peaks so she can get home for 8ish
The only time you can't use an 'Off-Peak' is before 9:30am(ish?). So if you're talking about the evening peak, then an Off-Peak is totally valid then :). The only tickets you need to be careful of are 'Super Off-Peak', which have much tighter restraints on them.
, right?
clagmonster
8 Jun 2005
Ulverston-Nottingham off-peak return tickets are valid on any train, except those scheduled to depart before 09:30 Mondays-Fridays. This restriction applies to both the outward and return portions. Therefore, with the times you have quoted, the £57.50 off-peak return is perfectly valid.
Is that 08:00 or 20:00 (8pm)?
This journey isn't being done same day as it takes at least 4 hours each way and leaving after 12pm and arriving back for 8pm gives no time at the destination.
It is impossible to arrive at Nottingham before 08:00, so I'll assume it's a trip that lasts a few days and leaves Ulverston on the 15:41 service, so there is no issue of it being a peak time and an Off Peak ticket is perfectly fine.
Ulverston 1541
Lancaster 1617 / 1657
Crewe 1759 / 1807
Derby 1924 / 1943
Nottingham 2005
Dodgy connection at Crewe, this may be better:
Ulverston 1541
Manchester Oxford Rd 1726 / 1739
Nottingham 1938
But you can't get that if splitting tickets at places like Stoke, so maybe the through ticket is best.
Mojo
7 Aug 2005
Not always, Cheltenham - Birmingham Off-Peak Day isn't valid before 09.30 and also between 15.30 and 18.15. There are other Off-Peak tickets that are valid at any time, and others with different restrictions.
