UKTrainSim
Baz37
9 Jan 2021
Wales
I have downloaded a few things from UKTrainSim, I've installed them but they aren't appearing in the editor, I have checked the Railworks folder & can see the folder created for the new item but the folder doesn't contain a "rail vehicle" folder. I was hoping somebody might be able to help.
Iskra
11 Jun 2014
West Riding
Do any of the files need unzipping?
Have you tried using the TS20XX Utilities programme? Some freeware needs that to help install it.
If they are reskins, do you need to copy a file from an existing loco you have, this is quite common to make reskins work. The readme may have further instructions.
Do you definitely have any other add ons that are required to make your download work?
Peter C
13 Oct 2018
GWR land
The folder created for the new item won't contain a 'RailVehicle' folder: if I remember correctly it should go Railworks > Assets > Developer > RailVehicles > Class of train > Versions.
The readme file(s) supplied with your download should help. :)
-Peter
_toommm_
8 Jul 2017
South West London
And have you copied across the relevant Geo files if you need to do that? The reskins won't distribute the Geo files as they're what make up the loco or unit, and to distribute those would be piracy.
Baz37
9 Jan 2021
Wales
To answer Peter C 1st the file path is Railworks>Assets>Traina>Trainset>PO_Bedwas. the readme file says I have to put the wagon into a consist to see the wagon(but as said I can't find it) I
_toommm_ I use ATSinstaler which moves the Geo files automaticall.
thanks for replying
