Uk headlights question..
trainfan3655
3 Apr 2025
USA
Hey, I have a question. In the UK I’ve noticed some class 66 locomotives running with all their lights on. Is the UK transitioning over to a full headlight set up instead of a daytime and nighttime running set up with the headlights?
driver9000
13 Jan 2008
Essentially yes although as far as I know there is nothing forcing an operator to change existing lighting to the new set up. The current standard is for twin headlights, markers and a roof height light which also allows an operator to do away with the yellow end if they wish. The new lighting style still has day/night settings with the lights being dimmed at night.
trainfan3655
3 Apr 2025
USA
I have seen some videos of this twin headlights set up and it looks to be extraordinarily dazzling.
driver9000
13 Jan 2008
Generally I don't have an issue with dazzling but class 68 and 88 locomotives are known for having bright lights.
martin2345uk
21 Sep 2011
Essex
374 headlights are bright enough that we are expected to "dip" them for oncoming trains
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
What does it mean to dip the headlights?
Set them to the dimmer setting for a train approaching in the other direction, but @martin2345uk put "dip" in quotation marks because it's from car/road vehicle terminology, where you're driving in the dark on an unlit road with no vehicle close in front of you or approaching in the other direction (and therefore you're using main beam/full beam/high beam headlights) but if for example (a) vehicle(s) approach(es) in the other direction, you pull the stalk to change to dipped beam/low beam headlights ("dipping" the headlights as in lowering the angle of them / tilting them down to a less dazzling angle, even if they're actually different lights).
With LED headlights / on trains, you'd technically be dimming rather than dipping.
furnessvale
14 Jul 2015
I have always supported the use of polarised glass in train headlights.
Given a different angle polarised sun visor in the cab, drivers could be protected from the glare, while trackworkers, crossing users etc, get the benefit of better protection
fgwrich
15 Apr 2009
Hampshire
I had noticed this with the new design of BMAC clusters fitted to some of the GW 150s.
For example, the older (and in my opinion personally) has the Day / Night mode where you’ll always have one light on each cluster on. On the newer version as seen on 207, it has all 4 lights on with varying degrees of brightness for Day / Night mode.
trainfan3655
3 Apr 2025
USA
Got it I do appreciate the explanation though! This is such a welcome information for me! I’m interested in everything train, headlight, and head code related.!
