Uk airspace retricted/closed
westcoaster
4 Dec 2006
DTOS A or B
Due to the volcano in iceland erupting, the ash cloud has caused the uk airspace to be restricted/closed until 1800, except for emergency diversions, here is the bbc reports, also found a free air traffic radar site here. the air space is usually very busy but at the moment is bare. this is only the second time this has happened iirc the last time was sept 11 , also here you can see what the ash can do to the engines.
flymo
22 May 2007
Geordie back from exile.
I remember this problem with Speedbird 9 back in 1982, it kind of started my fascination with flying and all things aviation. I saw the same guy Eric Moody on Sky News this morning and if anyone knows what the ash can do he and his crew do.
I think it was Cpt Moody, it may have been someone else, who once said "I'd rather be down here wishing I was up there than up there wishing I was down here".
I quite agree.
mbonwick
26 Oct 2006
Kendal
^No, they were closed at 1 point, but have since re-opened as the ash has moved further east.
mbonwick
26 Oct 2006
Kendal
According to the BBC, no.
It's so fine it just makes the sky look a little bluer than normal AIUI.
Peter Mugridge
8 Apr 2010
Epsom
There was a noticablity of fine dust on the cars in our road ( Epsom, Surrey ) this morning.
"Wrong sort of air!":lol:
2030720310
20 Jan 2009
The aviations equivalent of the wrong type of snow <D
I'm not sure if it is though, because if the ash gets into plane engines it can stall them and the plane will crash, so IMO I think its probably a good idea if planes aren;t flying into it!! :lol:
jon0844
1 Feb 2009
National Geographic showed the Air Crash Investigation (although it didn't crash) about the BA flight in 1982 the day before the planes were grounded. Freaky coincidence!
I've seen it before, and they were very lucky that the composition of the ash allowed the engines to restart when they dropped down beneath the cloud. Otherwise it would have almost certainly been a water landing.
37401
12 Nov 2008
Few mates in the north west said they can see some ash, maybe they know what to look for but I cant see sod all
Geezertronic
14 Apr 2009
I've seen that programme a couple of times before, only the skill of the pilots and a lot of luck saved the plane that day :|
90019
29 May 2008
Featherstone, West Yorkshire
Sod all here. A little bit of dust in some water on the back of the car, but I think that may have been from a passing truck this morning.
Sunset last night wasn't anything special either. Had much better, and much redder ones in the past few weeks.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
Maybe you need to get a little closer? !
Photos from Marco Fulle : (click on thumbnails to see larger images)
More images of the volcano here:-
http://www.swisseduc.ch/stromboli/perm/iceland/eyafallajokull_20100416-en.html
EDIT - update from NATS at 21:00 today (www.nats.co.uk) :-
Statement on Icelandic volcanic eruption: Sunday April 18, 2100
Based on the latest information from the Met Office, NATS advises that the current restrictions across UK controlled airspace due to the volcanic ash cloud will remain in place until at least 1900 (local time) on Monday 19 April.
There may currently be some limited opportunities in Shetland for flights, subject to individual co-ordination with ATC. However, anyone hoping to travel should contact their airline before travelling to the airport.
Conditions around the movement of the layers of the volcanic ash cloud over the UK remain dynamic. NATS is maintaining close dialogue with the Met Office and with the UK's safety regulator, the CAA, in respect of the international civil aviation policy we follow in applying restrictions to use of airspace. We are currently awaiting CAA guidance.
We are working closely with Government, airports and airlines, and airframe and aero engine manufacturers to get a better understanding of the effects of the ash cloud and to seek solutions.
The next update will be issued at approximately 0300 (local time).
HSTfan!!!
11 Jun 2005
I can understand how a jet engine would be affected, but can it affect a turboprop?
StoneRoad
6 Jan 2010
Haltwhistle
ash can also affect turboprops - there is a turbine in there!
If you look at Volcanic ash under a powerful microscope, you will see that the surface is very rough, and as it is also hard, being sucked past turbine blades threrfore erodes said blades (aka sand / shot blasting!)
If I remember correctly the BA plane that tried to fly in an ash cloud in the 1980's had most of the paint abraded down to bare metal and the cockpit windows / landing lights were so badly etched they were opaque!
I would also expect piston engines to suffer increased wear if they are run in ash-laden air.
royaloak
11 Oct 2009
today I will mostly be at home decorating
Yes it did, although the film was obviously dramatised for television I believe the pictures at the end of the film were of the actual plane involved.
MCR247
7 Nov 2008
UK airspace deffo closed until at leasr 1900 Monday
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Acording to my Local Travel update there is going to be no movements in UK AirSpace until atleast 1900 tonight.
So basicly seconded what MCR247 has said - oops!
Peter Mugridge
8 Apr 2010
Epsom
We've just been circulated at work by our corporate travel agency that it's now 01.00 tomorrow Tuesday...
HMG are apparently talking to Spain about flying the stranded passengers there and then bringing them home via Royal Navy and requisitioned merchant navy vessels...
