UIC Rolling Stock Numbering
USRailFan
2 May 2011
Norway
Mod Note: Posts #1 - #22 originally in this thread.
Or how about just moving to the UIC standard numbering system? :P
xotGD
4 Feb 2017
We could always try putting a letter prefix on locomotive numbers. How about D for diesel and E for electric?
sprinterguy
4 Mar 2010
Macclesfield
what letter would you use for battery and bi-mode?
Traditionally, bi-mode (i.e. electro-diesel) locomotives had an E prefix and were numbered in the electric loco range. The class 88s perpetuate this manner of classification under the TOPS scheme.
Not sure if there was a historical precedent for pre-TOPS battery locos? Though 'B' would be an obvious choice.
43096
23 Nov 2015
Or just use the UIC system, like everyone else does.
Shaw S Hunter
21 Apr 2016
Over The Hill
Try and find UIC numbering in the USA or Canada or Australia. Given the very limited connectivity between the GB and continental European networks I don't think it really matters to anyone else what system we use here.
Well it’s got a nice ring to it.
Well that's so much simpler!
I mean once you know what the bits mean it is quite simple!
The first two digits identify the type of vehicle (i.e. diesel locomotive, electric multiple unit, etc), the next two identify the country of registration the next bloc of four numbers and then three (i.e. 0043 096 in the above example) are up to the relevant country to use to identify individual vehicles as they see fit and then the final number is just a checksum.
It doesn't roll off the tongue to be fair but it's pretty logical!
So, to use an example pertinent to this thread, the first of the new class 69s assuming it is 69001 in UIC would probably end up being 92 70 0069 001-1 (I'm not sure how to calculate the checksum so that could be anything to be fair!).
furnessvale
14 Jul 2015
The trainspotters amongst us are not going to like that flying past at High speed! :D
BRX
20 Oct 2008
It doesn't resolve anything at all about the jumble that is UK numbering though.
Cowley
15 Apr 2016
Devon
Nicely explained there. Thanks. :smile:
Struner
13 Dec 2018
Ommelanden, EU
the checksum would be 2
Very true! :lol::lol::lol:
I'm not so sure it doesn't. It addresses the issue we have the moment where we have ranges in the hundreds for various different things. I.e. 1xx is DMUs, 2xx is DEMUs, etc but then have units which ignore that convention in some way (i.e. we now have 8xx for high-speed but 390 and 395s aren't in there). Under UIC those distinctions are handled under the type code which means that our existing choice of 395 for a high speed EMU is irrelevant as it would gain a 93 type code whilst a 331 would be a 94 type code creating the appropriate separation and "at a glance" distinction between them.
Our existing numbering almost becomes meaningless beyond being way of identifying individual pieces of rolling stock under UIC.
Thanks, just hope I got it right!! <:D
I bow to your superior mathematical capabilities!
Roast Veg
28 Oct 2016
We have a few conflicting carirage/loco numbers already - can anybody give an example of their respective UIC classifications?
TRAX
2 Dec 2015
France
you use the Luhn algorithm. so for your example you would proceed like this:
92 70 0069 001 is your number. You start by multiplying each number by 2 and 1 in a sequence. So:
9x2, 2x1, 7x2, 0x1, 0x2, 0x1, 6x2, 9x1, 0x2, 0x1, 1x2.
You end up with:
18, 2, 14, 0, 0, 0, 12, 9, 0, 0, 2.
You then do the sum of each digit and digit duo (so 18 is 1 + 8 = 9).
You end up with:
9, 2, 5, 0, 0, 0, 3, 9, 0, 0, 2.
After that, you do the sum of these numbers. Here, you get:
30.
Finally, you find out what’s the next multiple of ten after 30. It’s 30 (if your number was 36, it would be 40). There’s 0 between 30 and 30, so your check digit is 0. (If your number was 36 and your next multiple of ten was 40, your check digit would be 4, because you need 4 to go from 36 to 40.)
So your locomotive is UIC-numbered (it’s called the EVN number) 92 70 0069 001-0 (and not 2 as Struner said).
What do you mean ? Do you have any examples ?
Roast Veg
28 Oct 2016
Sorry, I meant carriage/unit. One example would be unit 444001, which conflicts with the DMSL in 385 001.
BRX
20 Oct 2008
Yes - I see what you mean.
However, the same could be achieved by adding a single digit on the front of our existing system, rather than an additional 5.
TRAX
2 Dec 2015
France
It is to be noted than in countries where the EVN system is in place, the whole 12-digit number isn’t used as the unit number. Digits 5 to 11 form the real number, the rest isn’t used as the true vehicle identifier. The EVN includes the vehicle number, not the opposite.
This is very important as the UIC numbering system numbers each vehicle individually, so that means locomotives (obviously), and each and every car of a multiple-unit. Thus a 4-car Class 377 would still need a general unit number as you wouldn’t use the 4 different UIC numbers of each one of its cars.
So the 5 additional numbers you mention (which are actually 4, the vehicle type and the country code) would not make their way onto the front of the train (look at German stock for example).
