Tyne and Wear Metro recruiting new trainee drivers
johnwilliam
16 Apr 2019
Hello!
First time poster. Was wondering if anyone could offer some clarity around the pay for this role?
The advert states:
If successful you will commence an intensive 6 month training programme, on a start salary of £18992 per annum rising to
£37,985 per annum (once qualified)
So are you qualified following 6 months and then the pay rises or is there another pay scale in between until qualified which may be in 1 year/2 year time?
Thanks
ModernRailways
21 Apr 2011
The pay really small.
This is why we're currently losing so many of our drivers. A lot of drivers are moving up onto mainline work, a few have moved to freight but we've lost a big chunk to Transpennine and Northern.
You get poor rates of pay, and you have to deal with everything. You're not just driving a train, you have to deal with anti-social behaviour, train failures along with multiple other things on a near daily basis and you must do so alone in most instances.
From what I've been told, they are looking to hire about 50 train crew in this intake.
Paper copies only, however my advice would be to do it electronically then print it out.
It should also be noted that if you're successful you'll likely be the last intake to drive the current rolling stock.
Frankfurt
23 Jan 2010
Transpennine Express, Grand Central, DB Cargo and DRS have all taken on metro drivers (between 30-35 in total so far in past 18 months) . Northern for whatever reason won't entertain metro drivers - their loss.
Frankfurt
23 Jan 2010
Hello!
The advert states:
Thanks
Just the one jump, half pay to full after passing out - approximately 6 months
Frankfurt
23 Jan 2010
if that’s the case then, does that mean they’d have to join as trainees and go through all the assessments as a non-qualified driver would?
Depends on the TOC/FOC. Some require it, others as we've seen don't.
Cyclist
5 May 2018
"NB: PLEASE NOTE THAT CV’S WILL NOT BE ACCEPTED AS PART OF THIS APPLICATION AND MUST BE COMPLETED IN BLACK INK IF HANDWRITTEN OR TYPED"
What's the point of part 2 of this sentence?
johnwilliam
16 Apr 2019
Frankfurt - thanks for the reply.
Once passed out is that the top end of the pay scale or are there further increments?
Thanks
Stigy
6 Nov 2009
I’m intrigued now haha. So what assessments to prospective Metro drivers have to undertake? I assume its different to the usual psychometric tests?
Frankfurt
23 Jan 2010
Exactly the same testing as prospective "mainline" drivers.
Cyclist
5 May 2018
Many TOCs close their applications early because they are done online. I’m assuming Nexus won’t do this because of the paper nature of it. Anyone know for certain?
Stigy
6 Nov 2009
I can’t believe people still use paper? DB cargo did until I checked last week and see they’ve updated it, but other than that most are online these days.
Cyclist
5 May 2018
agreed. I'm guessing Nexus being a public body can't afford to upgrade their recruitment system
skelator52
22 Apr 2019
are the metro drivers tested to the national rail group standards? does the 2 strike rule system still apply does anyone know?
Stigy
6 Nov 2009
According to the answer I received earlier in this thread, the Psychometric assessments are the same as for a train driver (at least national standard). I’d imagine the two strike rule still applies.
Harrison108
15 May 2019
Hi,
I am new to this board. I applied for the Train Driver job for Metro. Has anyone else heard anything back yet? I know it said up to 6 weeks. Just wondering.
ChrisRS
17 Jan 2019
Hi,
Not yet no. It did say deadline for a response is 31st July 2019 then assume its been unsuccessful.
Cyclist
5 May 2018
Hi,
I haven’t heard either. Be prepared for a long wait because previous rail jobs I’ve applied for have been similar.
Owen2323
18 May 2019
I've put in for this too and am totally new to the idea of train driving and the recruitment process other than the brief research I've done on here (I've not heard anything yet either and wouldn't really have expected to at this early stage).
Good luck to all prospective candidates and I'll post if/when I hear anything...…...
Owen2323
18 May 2019
Seeing as the pay seems to be a fair amount lower than mainline/freight work would it be fair to say that the application process for Metro will be less fiercely contested do people think?
Stigy
6 Nov 2009
Probably not, because it’s still well paid compared to a lot of other jobs, especially oooop north.
Cusaeng
18 Jul 2017
Definitely not. They receive thousands of applications every time they advertise for jobs and just like all other TOC’s they have the ability to pick and choose. A lot of people want to work for them as it’s a good wage for the area.
