Philip
Do you think the 'Tyldesley Loop Line' between Patricroft and Leigh has a strong case for reopening and either way where are the biggest tangible obstacles on the line of route? I don't know what it is like further west but between Monton and Ellenbrook the line doesn't look particularly difficult to restore - the loopline footpath uses the old trackbed along here and the platform for Worsley Station is still in situ.
Furthermore, I think this is a case of a closed line which would be well used if it did reopen; it would put Leigh back on the railway map and provide a much quicker journey into Manchester than the bus. If extended to Wigan via Hindley then this too would be well used as Leigh and Wigan are both large neighbouring towns. Worsley is like a smaller version of Wilmslow, so this would probably see decent numbers of passengers using the train to travel to Manchester and beyond. Monton is a fast-developing and trendy suburb of Salford, not unlike Chorlton, so a reopened station here would also probably be well used and, again, quicker than using the bus.
