Twyford - Taunton Day Return
autotank
6 May 2010
Oxfordshire
Hello,
I'm making a day trip to Taunton on Friday 13th hoping to leave at 0917 (arriving Taunton 1053). I want flexibility in the train I return on. I have a Zone 1-4 annual season ticket.
If I understand the rules correctly could I use the following combination of tickets to travel and not have to use trains that stop at the splits?
BZ4 - Bedwyn CDR £18
Bedwyn - Pewsey CDR £5.4
Pewsey - Westbury CDR £7.8
Westbury - Castle Cary CDR £8.9
Castle Cary - Taunton CDR £8.7
Total £48.8
If I get the following combination I obviously have to travel via the Berks & Hants but are there any services I couldn't use?
Any advice on better splits (and what prints out I should take with me to avoid arguments!)
Thanks in advance!
If your journey is from London, that's fine.
It's not valid if your journey is from Twyford.
TheWalrus
6 Oct 2008
You will be lucky to find a service calling at all those stations on the outbound and return trips.
Searle
4 May 2012
Ladbroke Grove
It doesn't have to stop at those stations as the London Z1-4 ticket is a season
If the journey is from a station covered by his Season, then condition 19c applies, so none of the train doesn't need to call anywhere.
Confusingly the title conflicts with the message content, so clarification has been sought.
autotank
6 May 2010
Oxfordshire
I'm travelling from Twyford but was wondering if I could use the above combination and start/finish short? From what I've read above I think the answer is probably no.
Any tips for splits that could make a decent saving on the £72.50 Off Peak Return fare?
LexyBoy
23 Jan 2009
North of the rivers
Correct, as you are not using your Season ticket for part of the journey.
One option would be to travel into London (£9.70 TWY-BZ4 CDR), this would of course add to the journey time.
Another obvious split is:
Twyford - Didcot CDR £5.90 (Gold Card)
Didcot - Bristol Parkway CDR £22.60
Bristol Parkway - Taunton CDR £12.50
Total £41
You must use trains which call at Didcot, which isn't a big limitation - you might even be better off changing there. Travelling this route is slightly slower but not hugely so (and trains are more frequent, even allowing for Didcot).
NB I've chosen Parkway; the tickets are the same price if you use Temple Meads and both are valid either way.
