The driver's instructions for the Blue Pullman describe an EP brake system that provides a higher brake force (higher brake cylinder pressure) when speed rises above 40 mph and until speed falls below 30 mph.
At lower speeds the brake cylinder pressure would be the 45-50 psi normally obtained from the air brake distributor.
What pressure was used at higher speeds? The main reservoir pipe was charged to 110-125 psi, but I doubt that the BC pressure was allowed to rise that high.
Does anyone happen to know the brake forces or brake percentages of the vehicles on the Blue Pullman train?
HST power cars seem to be the reverse of other two stage braking, with lower brake force (34%) at higher speeds (above 145km/h) and higher brake force (50%) below that speed.
The instructions for the prototype describe the same two stage braking on Mk 3 carriages.
Can anyone provide further information about this or give the brake cylinder pressures used? (And brake % for the carriages?)
Similar question for European stock with two stage braking. "R" or rapid braking on stock with cast iron brake shoes required higher BC pressure and brake force to be used on stock with cast iron brake blocks.
Further information on actual brake cylinder pressures would be welcomed. [Brake weights given on UIC stock give an indication of stopping distance in G, P or R modes, but do not relate directly to brake % as used historically in UK.]
