Does it start at 8???
tonight 2100 on the National Geographic channel,
Typical kack when it came to the signallers part though:roll:
I have two question after watching this.
1) The stop message. Does this really happen as I thought it was a verbal message over the cab radio rather than a visual message?
2) After signal SN109 why would the point have been at reverse not normal. I thought two points that form a cross-over are cross-interlocked so they are either both normal or both reverse (or was the signal diagram they showed not the correct one?)
Also they showed the Thames train leaving Paddington with a series of red lights,rather like a racetrack start,as its ready to start signal!
I had the same thought as well. I have looked on Rail Archives at the track diagram and the line that the Thames Turbo was on (Line 3) ended after signal SN109 by either converging on to the Down Relief or the Up Main. I have attached the link as it shows it far better than I can describe it.
http://www.railwaysarchive.co.uk/documents/HSE_Lad_Track001.pdf
