Tunnels??
tunnels
3 Dec 2022
Telford
Hi All,
Had some excellent advice last time so I thought I'd ask again
Are there any/many tunnels between Manchester Piccadilly and Morecambe?
Any advice very appreciated.
Thank you
None, if you use one of the handful of trains that run via Golborne Jn and Wigan NW.
One very short on the Atherton route to Wigan, and one longer via Bolton (which is the normal route to Preston and beyond).
tunnels
3 Dec 2022
Telford
Thanks so much. I've had a look and it looks like a majority of the trains go via Bolton. Do you know how I can book the trains via Golborne Jn ? Do they run daily/weekly? Thank you
30907
There is usually one train an hour via Golborne Jn. The best place to look for these would be to use a site such as RealTimeTrains.
As you can see, these trains run in the peak hours. There are also a few trains that run Manchester-Preston nonstop via Wigan - you can identify them because obviously they don't stop at Bolton :)
tunnels
3 Dec 2022
Telford
Thanks so much for your advice ☺️
This is a silly question, but how do I book this journeys ?
Also I tried to search for a journey back to Manchester but it didn't work
Any advice very much appreciated.
Thank you
peterblue
25 Jun 2018
Lancashire
It won't work if you type in 'Golborne Jn' into the calling points field. It needs to be a station where the train physically stops to pick up or drop off passengers, otherwise it will show no results. The best way to do is it to type 'Golborne Jn' into the first 'Location' field and then filter by TOC and time to narrow down the search results.
You can book this as you would book any other ticket. Standard flexible day returns start from £21.90 undiscounted, valid on any train between Manchester and Morecambe via Preston. It will be cheaper if you have a railcard.
tunnels
3 Dec 2022
Telford
tunnels
3 Dec 2022
Telford
Hi Peterblue,
Thanks for your advice, very much appreciated.
Does the journey attached avoid all tunnels?
Thanks again
Mcr Warrior
8 Jan 2009
Travel via Chorley means using Chorley tunnel, but it's not too long at 124 yards. Also there's Moor Lane Tunnels near Bolton station (77 yards).
Travel via Atherton and there's Pendlebury tunnels (201 yards) and Pendleton tunnels (52 yards) both near Swinton station.
tunnels
3 Dec 2022
Telford
Thanks for this
Can I avoid these tunnels?
Does the attached journey avoid them?
tunnels
3 Dec 2022
Telford
If I travel tomorrow from Lancaster (if the trains are back up and running) is there a train that avoids all tunnels? I've had a look and it looks like all of the trains go via Bolton
Mcr Warrior
8 Jan 2009
@tunnels. In post #11, are you travelling all the way from Glasgow Central? If so, there's a short 200 yard tunnel at Eglinton Street shortly after departure.
tunnels
3 Dec 2022
Telford
Thanks for getting back to me
I'm travelling from Lancaster to Manchester Piccadilly tomorrow (if the trains are running).
Most of them go through Bolton and I believe there's a tunnel on this line
tunnels
3 Dec 2022
Telford
I think I've found the train that avoids all of the tunnels as it goes via Golborne Jn. Is that right?
30907
Yes.
The only other train I can see tomorrow is at 0926 from Preston, and I don't think you can make that from LAN.
Be aware that if the service is disrupted it MAY be diverted via Bolton and that won't be announced.
tunnels
3 Dec 2022
Telford
Yes.
Thank you for this it is really good to know.
Is the tunnel before or after Bolton? If I got off the train before/after I should e able to avoid the tunnels?
30907
There is a very short one after Buckshaw Parkway and the main one is after Bolton - but the train won't stop there if it is diverted.
Your only alternative is to go to Warrington BQ and change there, but your ticket might not be valid.
Mcr Warrior
8 Jan 2009
As was mentioned upthread, the tunnel between Buckshaw Parkway and Chorley is 'Chorley tunnel', which is only 124 yards. The one approaching Bolton station, i.e. 'Moor Lane tunnels' is even shorter at just 77 yards.
Appreciate, however, that you don't particularly like tunnels of any length, even the relatively shorter ones.
