Ploughman
I must have been imagining it then when working on the track over many years in Standedge tunnel that there were no shafts.
Shafts were used to extract the material and play a part in maintaining the alignment by use of Theodolites, telescopes and indicators all using the shaft.
Most of the spoil extracted went up the shafts and was dumped around each shaft on the surface.
Some of the I think 8 shafts (could be more need to check that) have been infilled but at least 5 are visible on Google Maps Satellite view.
The links to the old tunnels and the Canal tunnel act as a pressure relief but that is by accident and not by design.
Ventilation in this tunnel and most others rely on the prevailing wind either directly blowing through or by the action of the wind blowing across the top of a shaft and creating an updraft.
