in manual driving mode S Stock can reach 62mph - though the acceleration rate is far slower than CBTC and you need long distance between station stops and downhill run to achieve it.With limiters off can an s stock reach over 60mph or can it's motors actually not go over 60
Also what's the slowest speed on the tube and were is it?
Upminster pfm.3 is 7mph; pfm.4 11mph, pfm.5 14mphUpminster for example - has 10mph and 15mph approach speeds.
They did substantial testing at Derby and Old Dalby before delivery to LondonThey should have a really fast test track were they go all out with train on test to find the top speed
To do that, the mythical "they" would have to spend a lot of money for no practical benefit whatsoever.They should have a really fast test track were they go all out with train on test to find the top speed
You get loads of the story's of a stocks reaching 70mph but I have no idea if they are trueDidn't a set of A stock touch 74mph 'unofficially' on one of the (then) 70 sections on the Met during its farewell trip?
Any advance on 74mph for LU stock...?![]()
The A stock was built and authorised for 70 when new. That was also the line limit on the Met fast lines.You get loads of the story's of a stocks reaching 70mph but I have no idea if they are true
Wiki has it down at 70mph (though it's not always reliable)
Dose anyone know why the line speed was decrease I bet the s stock could do 70 if not 75mphThe A stock was built and authorised for 70 when new. That was also the line limit on the Met fast lines.
In around 2000, the maximum speed of the A stock was restricted (by notice, nothing was done mechanically) to 50mph.
For the farewell tour, I understand that 70mph running was sanctioned but that a number of recorders on board clocked a maximum of 74.
0mph; stations and sidings...Also what's the slowest speed on the tube and were is it?
Much of the sub-surface Lines now operate CBTC without tripcocks and has been mentioned did operate to 70mph with them.The tripcock system on the LU only allows for a maximum speed of 60mph anyway so the question is moot.
70mph on most mainline stock feels slow and steady, whereas 70mph on the A stock was an exciting ride! Very bouncy I recallThe A stock was built and authorised for 70 when new. That was also the line limit on the Met fast lines.
There were claims that well over 70mph was achieved with A stock back in the day- mainly ECS non stop runs downhill from Amersham to Rickmansworth but at those speeds the back EMF from the DC motors was effectively equal to the traction current creating an almost natural speed limiter.Much of the sub-surface Lines now operate CBTC without tripcocks and has been mentioned did operate to 70mph with them.
This is a bit off topic but why is the tube always such a bouncy ride even at slow speeds is it just a matter of track quality
I sware met line trains have better track qualityPartly track quality, but mainly due to lack of space restricting the size of shock absorbers, coupled to relatively short wheelbase bogies. Also a crush loaded tube car is something like 3 times weight of empty one, so the stiffness of springing is rather a compromise.
That would also explain why tube train maximum speeds are not much more than 60mph. A combination of poor quality track and inadequate suspension system for higher speeds.Partly track quality, but mainly due to lack of space restricting the size of shock absorbers, coupled to relatively short wheelbase bogies. Also a crush loaded tube car is something like 3 times weight of empty one, so the stiffness of springing is rather a compromise.
A Stock speedos were marked up to 70, two further unnumbered marks were evenly spaced after 70 and I have seen the first mark reached.There were claims that well over 70mph was achieved with A stock back in the day- mainly ECS non stop runs downhill from Amersham to Rickmansworth but at those speeds the back EMF from the DC motors was effectively equal to the traction current creating an almost natural speed limiter.
What would be the benefit - it would take slightly longer to then reach "top speed" and you'd have to brake earlier. You would, I would think, at best save a few seconds on the overall journey time.They should really just upgrade the track I can think of quite a few areas where the tube could do more than 60
Maybe on bits like fast met line tho still fair pointWhat would be the benefit - it would take slightly longer to then reach "top speed" and you'd have to brake earlier. You would, I would think, at best save a few seconds on the overall journey time.
