Truro - Westbury
SWTH
12 Mar 2013
Shrewsbury/Porthmadog/Exeter
Hi, i'm in need of a little assistance.
I need to go from Truro to Westbury (Wilts) on Friday 7th Feb, arriving no later than 1015. I am unsure as to my return time; it will most likely be after 1330.
I could consider breaking my journey to Westbury overnight, depending on where and when. I hold a Devon & Cornwall Railcard.
The best I can find is the 0434 FGW service from Truro, arriving in Westbury at 0835, an Anytime Return is £86. Splitting the journey at Exeter could be cheaper by a couple of quid, but is dependent on getting an advance return on certain trains.
Thanks in advance!
TheWalrus
6 Oct 2008
Im sure theres a train leaving Penzance at around 0541 which runs direct to Westbury arriving 0958? That would be just in time for your 1015 arrival.
starrymarkb
4 Aug 2009
Exeter
Whiteball Tunnel is closed so services are being diverted via Yeovil adding ~1 hr to journeys (exact time depends on the slot on the single track West of England Line - some services have waits to cross HSTs/159s at Pinhoe/Honiton/Axminster/Chard Jn/Yeovil)
Romilly
5 Nov 2013
As regards fares, the following was the best that I could see:
Truro-Plymouth £16.20 anytime day return
Plymouth-Exeter St David's £18 anytime day return
Exeter St David's-Westbury £40 anytime return
Total: £74.20 (you could save another 60p by splitting Exeter-Westbury into Exeter-Castle Cary and Castle Cary-Westbury)
All trains that I could see call at Plymouth and Exeter so these splits should be valid on the outward through train and any obvious trains coming back.
Actually, with the help of Trainscanbecheaper, I have come up with something better:
Plymouth-Totnes £8.90 anytime day return
Totnes-Castle Cary £29.70 anytime return
Castle Cary-Westbury £9.70 anytime day return
Total: £64.50
Your 0434 outward train, and most return trains apart from the 1728, call (as is required) at all of the splitting points: the 1728 coming back does not call at Castle Cary.
If you might want to get the 1728 then, for Totnes-Westbury, buy the £43.50 anytime return, giving a revised total of £68.60
