Trouble with Screenwash Nozzles
CarltonA
22 Apr 2012
Thames Valley
Anybody have experience with blocked screenwash nozzles?
I've got a seven year old Kia, which is getting blocked nozzles every year. I think the culprit is dust and tree pollen getting in. I've sprayed WD-40 and glass cleaner down with limited effect. I've given up screenwash in the water as that seemed to make it worse.
Speed43125
20 Jul 2019
Dunblane
Funnily I was dealing with this earlier this week with on an old MR2 that's been off the road for a number of years.
What worked for me (without resorting to detaching everything and soaking in vinegar), was to poke at the two nozzle holes.
The suggestion I read online proposed using little needles, but I used individual wires from a wire brush and picture wire. Try and stick the wire as far into the nozzle ends as you can.
This did involve taking the nozzle off the car to make life easier, but I don't see why you couldn't try with it on the bonnet still.
CarltonA
22 Apr 2012
Thames Valley
Interesting, thanks.
The nozzles in question are small rectangular openings made from plastic, the pins won't help there. The bit of wire could be worth a try. I've got a weak clear vinegar solution in the reservoir which I'm trying. The pipework seems to be PTFE so hopefully no ill effects.
LYradial
8 Jun 2024
welsh marches
I found it helped if you get a mate to activate the washers at the same time as you are using the wire, otherwise you are just pushing the muck further down the hole
izvor
11 Jun 2014
on the SER
Or a spouse, after all that's what they are for isn't it? I'm sure there's something in the marriage vows about helping with nozzles.
Acey
16 Nov 2018
I'm not sure WD40 is a good idea ,isn't it oil based ? which may make things worse !
AndrewE
9 Nov 2015
At one time I used to have to drive an old work car which suffered repeatedly from this. I ended up by syphoning out the screenwash tank and all the bacterial slime that was in it, then putting in dilute bleach and poking out the jets with thin wire and flushing them through.
Bought screenwash concentrate usually has a biocide in it... It prevents bugs growing on the detergent or alcohol in the diluted mix which leads to this problem.
By coincidence some time later I read a report of some research which found that a disproportionate number of commercial vehicle drivers had antibodies to Legionella bacteria, which was put down to the use of plain detergent in the screenwash bottles. Warm water containing nutrient which was stagnant for a while and then a spray generated provided a very plausible explanation for their exposure.
p.s. and it has made it to the mainstream: https://www.cdc.gov/niosh/bulletin/2022/legionnaires-truckers.html
("Legionnaires' disease occurs at twice the rate in transportation workers as in non-transportation workers. Among the transportation workers reporting Legionnaires' disease, most (77%) were driver/sales workers or truck drivers."
and
"The bacteria that cause this illness grow better in water than in full-strength wiper fluid. When using a mix of wiper fluid and water, the bacteria can grow in the wiper fluid tank; if this happens, people may breathe in the bacteria when they mist their windshield to clean it.")
PaulC1309
27 Nov 2019
My Seat Leon had a nozzle that blocked regularly until I took it off and soaked it in hot soapy water then also put it in the dishwasher. Has worked perfectly ever since
AndrewE
9 Nov 2015
that must be the answer then...
