Trivia: Worst designed train toilets
Peter0124
20 Nov 2016
Inspired to post this whilst travelling on a Class 730.
I have to say the (accessible) toilets on these units are poorly designed, with the sink being too small and the water hole being at the very edge rather than in the middle of it, meaning the floor ends up soaked when the train begins moving or slowing down.
Also what is it with hand-detection hand dryers? Half the time they don't even turn on when you put your hand under! Wouldn't it be better to have a button that switches it on for say 30 seconds?
Are there any other train toilets on the network which are poorly designed or difficult to use? The Pendolinos are the best in my opinion, however the hand-dryer still constantly turns on and off when hands are still underneath.
D6130
12 Jan 2021
West Yorkshire/Tuscany
The refurbished ScotRail class 156 units. The location of the double sliding doors makes it quite difficult to manoeuvre a wheelchair in and out. Once you get inside, there's plenty of room for manoeuvre though.
Kite159
27 Jan 2014
West of Andover
The sinks on the Flirts I found are a bit poorly designed in the water shuts off straight away after you move your hand from the sensor, rather than remaining on for a few seconds to allow hands to be washed.
Special mention to some of the retro-fit toilet units on 150s where the toilet itself doesn't give much legroom when you are sitting down
Sakuradori
5 Jul 2024
Bedfordshire
Class 222 toilets have a full floor to ceiling mirror angled directly at yourself while you sit. Great if you want to inspect your posture.
RUK
5 Aug 2009
East of England
I find the same problem with the FLIRTs’ toilets - the water barely stays on.
Class 700s’ non-accessible toilet’s doors are roller doors, which roll forward and back and bang open and shut noisily when not in use, whenever the train accelerates or brakes.
FrodshamJnct
14 Apr 2019
Cheshire
Has to be TFW going all in on their Standard Premium offer only for it to be deemed unviable as not PRM compliant. It was a shambles - both in design and their subsequent comms around it.
Russel
30 Jun 2022
Lichfield
On the 730's, the small toilet is no better, you can't get into a comfortable position to use the sink resulting in water covering your arms...
Merle Haggard
20 Oct 2019
Northampton
I've posted about the very poor 730 toilet washbasin water on the Forum before - if you hold your hands under the outlet inevitably water runs along your hands and onto the floor, however hard you try to stop it.
I travelled a couple of times on Cambridge - Kings Cross emu (not sure of the class) They have three widely space push buttons - soap, water, dryer. (then last from memory, not sure) One might expect that, when one presses the 'soap' button your other hand should be positioned underneath the button to catch the soap - but no. it emerges from underneath the water button. Wrong! In reverse with the water. I suppose you could get used to it with practice.
It's an interesting reflection on train designers, constructors and testers. With the 730s presumably they all thought 'The floor gets wet, but, apart from that irrelevant detail, i've done a brilliant job'. .
Cl 350 hand dryers cut off in neutral sections (fair enough, can't waste battery power) but they do seem to take a long time to re-start.
rmHawk765
8 Apr 2025
ECML South
*In theory* these are supposed to have some sort of locking mechanism but it is so weak that on most units the doors do indeed just slam about all the time.
Mikey C
11 Feb 2013
Train hand dryers are reminiscent of the hand dryers in public toilets 20 years ago, before the newer generation of way more powerful ones (like the Dysons) appeared...
rmHawk765
8 Apr 2025
ECML South
I do not even bother when I see (or use, because you can't really know beforehand on a train) one of those ancient dryers.
The Dyson Airblade design (and all the copies) is the best (or paper towels, anyone?), but there is no reason you can't fit something smaller but still usable in a train. The main issues you can have with a dryer are that it is too slow, it freezes your hands in the winter, or it just blows all the water onto the floor (or even water off the sink onto you). Trains tend to have 2 out of those 3 problems, and I'd much rather just have some paper towels if a proper design can't be worked out.
Also, foot buttons (as seen on unrefurbished TGV trainsets for instance) are far superior to sensors or buttons. No need to touch a button which has probably been touched at least a good 50 times since the last time it was cleaned, and no need to wave your hands around like an idiot under a broken sensor. For accessible toilets regular buttons can be kept.
eastwestdivide
17 Aug 2009
S Yorks, usually
Hand dryers on many 158s are beyond feeble.
Very narrow sinks in IET small toilets, hard to get your hands under without touching the back and dripping on the floor when your fingertips are under the sensors.
Sensors that aren't aligned with the symbols for soap, water, air.
Mind you, I also hate the non-train dryers that are both so loud it hurts and also blow drips over your light-coloured trousers, making look like you've "had an accident".
Think I'll hold it in and wait to go behind the nearest tree.
milooo
3 Dec 2024
Stevenage
Speaking about powerful hand dryers... The 387s' (unsure about the others) hand dryers blow water everywhere
31160
18 Mar 2018
Well for my vote I would say the Caledonian MK5s, now these are trains where most peeps would like a good wash in the morning when you're about to get off at your destination but how your supposed to do that when you can't bend over the sink, all you can do is just get the floor soaking, not much thought used, obviously if you're in any berth this doesn't apply
Merle Haggard
20 Oct 2019
Northampton
I recollect using a very powerful hand-dryer in a small-type lavatory and it quickly heated the whole lavatory up to oppresive sauna heat before my hands were dry, so that may be a reason they're not usually powerful. I wish I could remember the train type, but I can't. Might have been a refurbished older stock one. .
RUK
5 Aug 2009
East of England
That’s why the Dyson Airblade type are better - as per the name, the sheet of air jetted out is meant to be a blade which scrapes the water off your hands, rather than the air being warmed - hence they work best if you put in and pull your hands in and out of it as quickly as possible as many times as possible to scrape water off them with each pass, which I see a lot of people don’t seem to get the principle of - some people just stick their hands in there and leave them there, which doesn’t work well with them. The Airblades can get gunky at the bottom where the water ends up, and they can end up not draining the water, though, blowing it to the floor, which wouldn’t be good for a small train toilet - I don’t know if they’re hard to clean out, but they (except the Airblade V, which doesn’t have the cavity, but having the air jet on only 1 side of each hand, doesn’t work as well) do need to have the drain maintained and be cleaned, whereas the traditional type of hand dryer doesn’t have that issue/a drain/internal cavity to clean out. I find the alternative versions such as the Mitsubishi Jet Towel even worse for seeming to get smelly/unhygenic, though. Airblades are fine if maintained, but can get gross if not.
Merle Haggard
20 Oct 2019
Northampton
That’s why the Dyson Airblade type are better - as per the name, the sheet of air jetted out is meant to be a blade which scrapes the water off your hands, rather than the air being warmed - hence they work best if you put and pull your hands in and out of it as quickly as possible to scrape water off witch each pass, which I see a lot of people don’t seem to get the principle of - some people just stick their hands in there and leave them there, which doesn’t work well with them. The Airblades can get gunky at the bottom where the water ends up, and they can end up not draining the water, though, blowing it to the floor, which wouldn’t be good for a small train toilet - I don’t know if they’re hard to clean out, but they do need to have the drain maintained and be cleaned, whereas the traditional type of hand dryer doesn’t have that issue/a drain/internal cavity to clean out. I find the alternative versions such as the Mitsubishi Jet Towel even worse for seeming to get smelly/unhygenic, though. Airblades are fine if maintained, but can get gross if not.
That's reminded me of an irritation with cl 350 hand dryers.
You have to get your hand in exactly the right position, and for it to be static for a time period, to persuade the heater to switch on. Move your hand and it switches off. But the whole point of an electric hand dryer is you rub your hands together to make the drying process work! Don't the designers know this ???
May also apply in other classes, but the Pendo ones are great and allow you to move your hands vigorously without cutting out.
fgwrich
15 Apr 2009
Hampshire
Another vote for the Hitachi designed units. Not only for the aforementioned issues above with the dodgy sensors, water jet, shallow sink design which if you use the sink whilst the train is moving results in the water ending up on the floor, all round cheapness of the plastic walls but also the somewhat irritating door design with its very heavy sliding mechanism, and door handle design which manages to catch splashed water from the sink.
I’ve certainly seen people of all ages struggle with those doors.
Special mention to the original Networker / Turbo design too. Ridiculously narrow door with cr*p hinges, a smooth curved counter design with a rubbish tap that more often that not ends up dribbling the water out, down the wall and straight onto the floor. And a rubbish hand dryer to boot.
The small toilets on 222's where you don't even have room to open your legs. Too cramped.
Goldfish62
14 Feb 2010
Exactly the same issues on the 701s. The soaked floors give the impression of the toilets being filthy even when they're not.
Mikey C
11 Feb 2013
I was a GWR 800 on Tuesday (800313) and there was clearly a blockage somewhere, as the sink (in one of the small toilets) wasn't draining properly, splashing water everywhere as the train jolted along...
The exile
31 Mar 2010
Somerset
Not specific to train toilets, but one solution to that would be to have an adapted “open bottomed” version above the sink so a separate drain is unnecessary.
Russel
30 Jun 2022
Lichfield
Yeah, how these even got past the design stage is a puzzle... I don't even bother trying them, I just use my trousers!
There is other classes of BR stock that also has the same "dryer" type, possibly the GWR 165/166 fleet if I remember correctly.
And they seem to miraculously survive every refurbishment thrown at them !
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
The short-set HSTs were poor, the sink was not very wide or deep, so water often sloshed out on curves.
The exile
31 Mar 2010
Somerset
At the time, having a hand-dryer at all was revolutionary.
