Trivia: Wired Stations served mostly by Diesels
randyrippley
21 Feb 2016
Carnforth platforms are wired but only see an electric train if the WCML is blocked and the station is being used for reversals. No electric services stop there
route101
16 May 2010
Wonder how long goes between the wires being used ?
Regarding Newcraighall and Brunstane , didnt they have a 322 service from Glasgow?
Kite159
27 Jan 2014
West of Andover
Brunstane and Newcraighall are both electrified but see only diesel Borders Railway services.
Holytown, on the Shotts line, only sees diesels, after being removed from the Lanark service.
Slateford, Kingsknowe, Wester Hailes, Curriehill and Kirknewton see mainly diesels, however they do see a couple of electrics a day I believe.
Coatbridge Central and Whifflet used to see only 156s and/or 158s despite being fully electrified, this has changed now though.
The GLC-MIA TPE service is mainly run by a 185 these days, I think that may run under wires the entire distance?
Linlithgow and Lenzie certainly get peak electrics, Polmont probably does too.
There is a peak time service to Carstairs which serves Holytown and is electric (1700 Anderston to Carstairs, probably one of the least worked evening diagrams for an EMU in Scotland as it does that one service before returning to the depot)
scrapy
15 Dec 2008
I'd be surprised if Preston has more diesel services than electrics now. May 2018 timetable changes will make it majority electric for certain.
Northern currently have 6 to 8 departures an hour off peak (Ormskirk, Barrow, Windermere not regular hourly services) only one of these is electric.
TPE have 2 departures an hour. Not all these are electric.
Virgin have 4 departures an hour. Voyagers used on several of these.
April will see more diesels when Blackpool North reopens.
May should see some electric trains to Blackpool likely either 1 or 2 of the 4 hourly Northern services and some Virgin services. It will however also see more diesels as Ormskirk and Barrow/Windermere should go hourly.
I certainly think there will be more electrics than diesels by the end of this year (assuming Bolton line finished).
Stopper
11 Nov 2017
Are Voyagers used on several of those? Most Scotland-London services are a Pendolino
DanNCL
17 Jul 2017
County Durham
The Scotland - London services via the Trent Valley are usually 390s, but many of the Scotland - London via Birmingham services are 221s.
route101
16 May 2010
I think it varies at the weekend . I think theres more pendos than voyagers though.
Andyh82
19 May 2014
Interesting. I hadn't realised quite how many of the ECML stations were diesel only despite being wired! Although i suppose at least there the wires are used by fast trains passing through.
But if we put to one side local stoppers on electrified express lines, are there any big stations/terminii with similar issues to Leeds? I mean, wires on every platform but I imagine a lot of them (the Transpennine platforms for example) ever get an electric service even passing through - the wires have probably not been used on some of those platforms since installation!
In the case of Leeds, I know at the start and end of service VTEC use more platforms than normal in the middle of the station, but I don’t know if that extends all the way to 15/16, and not all these services are electrics.
Has platform 17 ever seen an electric
Are the eastern facing bays wired up?
I suppose for operational flexibility it’s better to wire up every platform.
rower40
1 Jan 2008
Not to my knowledge. Until the Borders line was built, Newcraighall station was wired, but the turnback siding beyond was not. Because the station platform was on a gradient, it was considered unsafe for a driver to change ends there, so everything had to be timetabled into the turnback siding and back again. And therefore it couldn't be diagrammed for an Electric Unit.
(Trains could change ends there in an emergency or to recover from service disruption, but there was an elaborate procedure involving the guard being in a position to apply the handbrake in one cab while the driver changed ends.)
EMUs to/from the new Millerhill stabling point will go past Newcraighall, but not through the platform.
steamybrian
26 Nov 2010
Kent
If you include DC third rail stations then I would include...
Millbrook and Redbridge which although on the Southampton-Bournemouth main line are mainly served by DMUs on the Southampton- Romsey/Salisbury services
Spartacus
25 Aug 2009
Has platform 17 ever seen an electric?
Yes, I was a bit surprised myself, but there is one booked to do it, the 1826 SO from Doncaster which goes back as the 1921, and it did run to 17 on Saturday (322484). I can't find anything booked to use 16, but there seems to be a few booked to use 15. Both 7 and 14 are wired, only time I could really see them being used is if an ECS set off for Neville Hill and had to come back for some reason.
scrapy
15 Dec 2008
Agreed most Scotland to London services are Pendolinos but Voyagers are used on several of the the services which operate via Birmingham including those few that start/terminate from Crewe.
randyrippley
21 Feb 2016
just remembered that one, possibly both of the northbound bay platforms at Lancaster are wired, and I suspect have never held an electric train due to their length. I presume the wiring was done under the assumption that Lancaster-Barrow / Morecambe / Windermere would be wired and worked by EMUs terminating at Lancaster
from this photo at http://www.chiark.greenend.org.uk/~owend/I/R/stnpages/lancaster.html its clear platform 2 is wired, possibly1
thenorthern
27 May 2013
Its 3rd rail and not wired but most the trains at Chester are diesel.
Most the trains call at Ardwick are diesel and most the trains at Dunbar I think are Diesel.
route101
16 May 2010
Dunbar not have 380s and 91 sets ? Or is it all HST with VTEC there
Stopper
11 Nov 2017
Dunbar is pretty much a 50/50 mix of diesels and electrics. Scotrail have bi-hourly electrics at Dunbar, and VTEC operate 2 or 3 also. XC operate diesels around bi-hourly I think and there are a few VTEC services which are diesels too.
Stopper
11 Nov 2017
It’s about 50/50 with the VTEC that call there. The Aberdeen-Leeds services have to be HSTs. XC operate bi-hourly diesels and Scotrail operate bi-hourly electrics.
thenorthern
27 May 2013
Tamworth is electrified on the low level but there are more trains overall serving it on the high level which isn't electrified.
Stopper
11 Nov 2017
Glasgow Queen St at the Moment .
Certainly high level. There’s 8tph each way electrics through. There’s around 10tph leave and enter High Level each hour I think, of which 2tph are electric. So overall, Queen Street is actually mostly served by electrics, slightly.
jopsuk
13 May 2008
Norwich for sure- in an average weekday off-peak hour there's two electric departures and five diesel
Crossover
4 Jun 2009
I first travelled on the line to Newcraighall in around 2011 and the 158 simply turned round in the platform at the time. I think a future visit saw the same happen. Never heard of Newcraighall having services run into a turnback siding
Crossover
4 Jun 2009
Only one platform, as far as I can recall, has third rail at Chester, not the whole station
