[trivia] Which stations are open 24 hours a day?
Are all major airport stations open 24-hours a day? The OP mentioned Manchester Airport which would be understandable seeing as it's the north's major airport hub even after the rise of more point-to-point flights, but what about the local Gatwick Airport station as well?
Gatwick Airport has a frequent enough overnight service to be open all night with passengers waiting on the platforms. Manchester Airport doesn't. Southampton Airport Parkway platforms can't be closed off (although the station buildings (and the airport itself) are locked up).
Sorcerer
20 May 2022
Thanks for the info. I can sort of understand with Gatwick seeing as it's a busier airport, but then perhaps that's not as relevant as the facilities at the station rather than passenger numbers.
Trainfan2019
9 Aug 2019
It used to have a 24 hour refreshment facility, which was pretty unusual. (Holyhead also had a 24 hour facility linked to sailing times)
However I suspect you would be quickly moved on these days between around 0040 and 0430 as there'd be no reason for you to be there.
Intriguing about 24 hour refreshments at Crewe. When did this end and where was it in the station?
midland1
18 Aug 2019
wigston
In the old BR timetables they use to list which stations had 24 refreshments. From memory Euston, B'ham NS, Crewe, Carlisle, Leeds, York, Newcastle Bristol TM, Holyhead. Also Sheffield and Darlington for a while. One or to closed for an hour or two for cleaning.
8 Feb 2021
Manchester
I want to say York is open 24/7, I’ve certainly been there at some ungodly hours and never found it locked, though this may potentially have been a little “unofficially open” shall we say
greyman42
14 Aug 2017
As far as i am aware it is open, no "unofficially" about it. Perhaps you can explain what you mean by "unofficially"?
And more specifically which stations would you run into no problems being at 24 hours a day?
Presumably the thameslink 24hr stations, Derby, Reading, Manchester Airport, Manchester picadilly. Where else?
Why does Derby remain open?
What is the situation at Peterborough?
I suspect the OP is basing their view on the last London train arriving (0305) very shortly before the first London train departs (0348). EMR's London services appear to be a near 24 hour a day operation with the ECS movements starting before the last train goes to the depot although I note that for the train to arrive in Derby as late as 0305 it needs to be diverted via Corby.
MikeWM
26 Mar 2010
Ely
There's a sign outside the toilets on the platform at Stansted Airport station that says they are open '24 hours a day'. Whether that is accurate, or whether only that part of the platform near the ticket office remains open - I've no idea.
Mcr Warrior
8 Jan 2009
Quite a gap (five hours?) between last service and first service at Stansted Airport.
nw12398
19 Dec 2021
Devon, United Kingdom
Exeter St Davids is relatively close to the middle of the Night Riviera route, for which trains stop for an extended period, requiring it to be open (as far as I know) for 24 hours.
Again, it will be cleared other than for passengers with intention to join the up Night Riviera just after 0100 then it can be locked up once it leaves. The preceding departure from Exeter St Davids is at 2340 for Exmouth with the later train to Plymouth being set down only. The westward Night Riviera doesn't arrive until after 3am.
8 Feb 2021
Manchester
It was a bit of a ghost town and it felt like I shouldn’t’ve been there, shall we say
I also happen to be at Leeds station right now waiting on one of the overnight TPEs and can confirm that I’m able to sit in the retail concourse bit, but not access the platforms until closer to the time of my train
Mack91
3 Dec 2019
Doncaster
I've been and photographed some trains at York in the early hours on a few occasions now. Nobody has ever stopped me, in fact I've had conversations with several members of staff, security and drivers whilst there. As long as I've explained my reason for being there, they seem perfectly happy. Several staff have said things along the lines of "You're keen to be out at this time!" to me. A bit of a joke is fine!
I do agree with the sense of it being a little surreal to see a place that's usually so busy be so empty and quiet.
_toommm_
8 Jul 2017
South West London
Not allowed on the platforms overnight (except for stranded passengers deemed to be vulnerable). Passengers used to be allowed to sit on the concourse but potentially that has changed and passengers need to wait outside.
Access allowed for the overnight departures shortly before they arrive then locked up again.
Concourse is still open, and gates open fifteen minutes before each departure. Normally littered with lots of drunks whenever I’ve arrived there on the 2am-ish arrival trains.
Sorcerer
20 May 2022
I mean Stansted is also a very busy airport so I would probably take them at their word on that one. Maybe there is a few catches though, to the point where it's only a 24-hour station by technicality. Someone else will probably have to confirm that for me.
Piccadilly opens for the overnight trains, though anyone with connections overnight is allowed to stay on the station. So it's open, but not open.
London Paddington stays open all night, as I found out the hard way one Saturday night in January...
Piccadilly is fully open all night. Always a few people kipping on the seats in the concourse - not necessarily obvious whether they are drunk, missed their last train or homeless! However, it can get quite chilly for an 'inside' area. I learned that the hard way!
Trackman
28 Feb 2013
Lewisham
When I went once late at night they only had the main entrance open (not counting the p1 entrance) with staff keep to undesirables out.
Perhaps, but the platforms are definitely still accessible.
ValleyLines142
25 Jul 2011
Gloucester
Seems to have (at least) hourly arrivals (or departures) from/to London St. Pancras throughout the night, as well as regular service buses to/from East Midlands Parkway.
I did just see a previous comment.
Checked on Real Time Trains and indeed that is the case! 03:05 arrival and 03:48 departure. I didn't realise!
plugwash
29 May 2015
They lock up the link bridge lounge at night, at least they did last time I was sitting there waiting for the last train to Heald Green.
