[Trivia] What station is highest from local ground level?
SynthD
4 Apr 2020
What's the highest station as seen from local streets, from the stairs to the platform, or in the drop from any end of the platform?
All the high viaducts I can think of end or shrink before a station.
61653 HTAFC
18 Dec 2012
Not exactly what you're looking for I suspect, but in terms of "horizontal distance/vertical distance" from the settlement served Denby Dale must be up there (no pun intended). However the station itself is at ground level, albeit up a hill from the main road through the village. Generally outside of urban areas it's easier to build the station on terra-firma rather than elevated, and certainly was in the 19th century.
alistairlees
29 Dec 2016
Some DLR station will be the highest I expect.
Also Blackfriars
py_megapixel
5 Nov 2018
Northern England
Lots of stations are on, or immediately after, a high bridge or embankment - but usually the roads come up to meet it.
If you're talking about the highest station above a single other street which it can be seen from, then something like Manchester Oxford Road above, well, Oxford Road, might be the winner.
But if you're talking about the highest station above all streets then that's a lot trickier. Here, Oxford Road can't win, because a small access road comes up to the level of the station itself.
How about Swindon for starters? And then there's Pontypridd, of course
Eh? Swindon's barely above street level at all!
HughT
21 Feb 2018
Cambridge
Following on from 61653 HTAFC's interpretation of the question - how about Tyndrum (the Upper station, obviously!)?
Jan Mayen
30 Sep 2020
Sussex
Assuming from street level, I can't think of any which would be much higher than an adjacent road bridge. Battersea Park, Queens Town Road Battersea for example.
The platforms at London Bridge are much higher than the natural ground level beneath them.
steamybrian
26 Nov 2010
Kent
London Bridge would be my shout for this one.
Internationally, the platforms at Seiano station (on the Circumvesuviana railway between Naples and Sorrento) seem a little dizzying: https://permanenttourist.ch/photo/15638306366/
London Bridge plats 10-15 are accessible on the level from the station approach.
In London my suggestion would be Fenchurch Street which has ground level access but the platforms are on the viaduct.
The next station Limehouse the platforms are wholly on a viaduct with access and ticket office at ground level.
Battersea Park, South Bermondsey, Queens Road Peckham and Peckham Rye the platforms are all on a high viaduct
alistairlees
29 Dec 2016
Gdansk airport will be in with a shout internationally. Possibly also some other stations on that line
Mcr Warrior
8 Jan 2009
Wivelsfield station platforms always seem to be a fair schlep up from street level.
Springs Branch
7 Nov 2013
Until it closed in the mid-1970s there was East Brixton.
East Brixton was on the South London Line, a bit to the east of where it passes above Brixton Station, which is itself on a viaduct above surrounding streets.
East Brixton had wooden platforms perched on top of spindly Victorian-era iron supports and always looked to be a bit higher above the street than the other Sarf Landan station-on-a-viaduct gaffs.
The Disused Stations website has a page at http://www.disused-stations.org.uk/e/east_brixton/, with pictures.
In this category Dent is the classic example - the village being nearly 5 miles by road to the west, and 400 ft below the height of the station according to Wiki.
Poolie
30 Jan 2010
I've been through Dent by train several times over the years, but watching Winter Walks on BBC4 I hadn't realised how high and remote the station is. That's some hike!
Parallel
9 Dec 2013
Maybe not the highest, but Polsloe Bridge is quite high up, it is accessed by a slope, then steps from Pinhoe Road.
I seem to remember Calstock is also very high up, there was a steep path down to the road when I last used it.
etr221
10 Mar 2018
For LU, based on 'station depth' spreadsheet from an FOI request (which I mentioned in a previous topic), the highest rail level compared to ground level outside station is Greenford, at 10.2 metres (the NR bay will be the same). Second is East Putney (8.0m)
urbophile
26 Nov 2015
Do you mean the whole station, or does your criterion include those with a ticket office at ground level and platforms above? If so, Earlsfield has a pretty stiff climb (and until the last few years, no lift).
AM9
13 May 2014
St Albans
I don't think Ambergate, Chelmsford or Sandwell and Dudley have been mentioned yet. And how about the High Level platforms at Tamworth ?
I'd agree that Chelmsford is pretty lofty, also in a similar way, (on land falling away to a 'floodable' river), so is Worcester Foregate Street.
61653 HTAFC
18 Dec 2012
The large horizontal distance was why I cited Denby Dale rather than Dent as my example, as the height difference in that case is fairly insignificant in relation to the horizontal distance.
Mcr Warrior
8 Jan 2009
Another possibility... Manchester Piccadilly (excluding the station approach).
Western 52
19 Jun 2020
Burry Port
Lots of steps up from the road to the south bound platform at Heath High Level - the station is built on an embankment. Until it closed in 1986 there were quite a few steps down to the platforms at Cefn Onn.
