Trivia: What are the sharpest curves on Network Rail routes?
30 Sep 2013
Weymouth
I'm talking about sharp turns/corners.
The sharpest curve I know of from my own journeys is just outside Battersea, where the Freight usually stands, has no 3rd rail.
I'm guessing the sharpest curves are not 3rd rail. If this is right can someone tell me why this is?
BantamMenace
2 Dec 2013
The sharpest I can think of is the climb and turn heading north out of Carnforth over the wcml towards Hellifield, 10mph and a serious screech from the wheels
civ-eng-jim
16 Jul 2011
Caxton Curve on London Underground's Central line has a 60m radius. 3rd and 4th rail.
Syston North to East must be a small radius too.
140metres.
The collector shoe is near the bogie centre so the tight radius is unlikely to result in the shoe deviating horizontally from the third rail.
I honestly cannot see the presence of a third rail being relevant. If a running rail can be bent into a particular curve radius, that allows a bogie to pass, then so can a third rail. Because the pick up shoe only rests under its own weight on the top, the mechanical issues associated with third rail current collection will always be less of a problem than the tightness of the curve on the running rails, and in any case they would almost always be able to put the third rail on the outside of the bend, so it would always have a greater radius than the running rails.
civ-eng-jim
16 Jul 2011
One issue with a tightly curved third rail is the way it's supported - Sitting on ceramic insulated pots provides very little (if any) restraint. Third rail would have to be pre-curved.
rebmcr
15 Nov 2011
St Neots
There are no RailTrack curves anymore, they are all Network Rail now.
NSE
3 Mar 2010
I was reading an article about the Morpeth crashes which seemed to suggest the Morpeth curve was one of the tightest
30907
Maybe in terms of a main line away from a major station, but no way in absolute terms.
Shipley Bingley jn to Bradford jn (aka platform 5) must be hard to beat. 5 mph IIRC , possibly 10.
PaxVobiscum
4 Feb 2012
You definitely mean "3rd rail" as in raised DC power rail rather than "check rail" - additional safety rail on curves and point work? Sorry if I'm questioning the obvious.
Mugby
25 Nov 2012
Derby
Another one might be the Lifford curve from West to East junctions at Kings Norton.
317663
30 Sep 2013
Weymouth
Curves that have 3rd rail systems (eg Blackfriars, Selhurst, Sutton, Three Bridges are examples of tight curves with 3rd rail involved. I'm guessing theres tighter curves that 3rd rail may not work well/have many faults with.
What about this at Firsby, Lincolnshire
e: also this thread
I think i've seen tighter ones than that but that sure is some sharp one!
Geeves
6 Jan 2009
Rochdale
The Brewery Junction Curve that allows trains from Newton Heath to gain access to the Ashton line is one of sharpest I know. Coupled sets have been known to end up becoming split here.
Also the curves at Dinting are pretty sharp too!
Deepgreen
12 Jun 2013
Gomshall, Surrey
The classic (and sharpest ever used in the UK) was on the long-defunct Cromford and High Peak line in Derbyshire (closed 1967), which also had the steepest adhesion-worked gradient in the UK at 1 in 14. The curve was known as Gotham Curve, had a radius of 55 yards and turned through 80 degrees.
There, that dates me (and I still haven't actually answered the question)!
Parallel
9 Dec 2013
Exeter St. David's to Exeter Central causes a fair bit of screech too.
