Trivia: Unsignalled, but electrified
How does the signalling and signaller know once the train is on the branch? How does the train get released at the end of the day? What stops another train being signalled onto the branch? Who does the driver contact in an emergency (or anyone else requiring a block)? How is the location of the train established?
You could say any form of automatic signalling doesn't require any input from anyone. Doesn't mean that there is no signalling
It’s one train working. At the start of the day, the unit is signalled on to the branch ; once it is clear of the track circuit protecting the branch the train is then ‘locked in’. The signaller then has no further interaction with it unless an issue arises, and then communication can be made by the GSM-R.
At the end of the day the driver will contact the signaller to request a route off the branch. I don’t know the exact arrangements at Watford, but it could be via GSM-R, or via a plunger on (or near) the platform.
One Train Working prevents another train being locked in the branch; both in the interlocking and through the paperwork procedures.
In an emergency, the driver contacts the signaller via GSM-R (or vice versa).
The location of the train is established by the driver telling the signaller where he/she is!
30907
Nope. There are signals at Sundridge Park and Bromley North
Not to mention double track almost throughout, 2 platforms and associated pointwork at BMN. It may be worked by one train these days but that's all.
AM9
13 May 2014
St Albans
As far as the signaller is concerned, the train takes a siding off the slow lines at Watford (which happens to be platform 11) which he/she then treats a a tokenless 'one train on branch running'* until the trains is released back onto the mainline. Return is protected by signal 856 and there is no connection to any other track including sidings north of that signal. The driver would have full contact with signallers via GSM-R.
Strictly speaking, the Bushey Mill Lane crossing is really no more than a track circuited operated pair of half-booms with AFAIK no functional connection to the WCML signalling system. The signals are really only there to warn the train to slow (and stop at the platform going northbound). Yes there is a signal facing away from the actual crossing, more like traffic lights.
* not sure what the signalling description of such a situation might be.
Ooops, didn't notice Bald Rick's more authoritative explanation above. That's the problem working with a tablet that repeatedly reboots unexpectedly.
I assume that my description of Bushey Mill Road crossing is somewhere near factual.
MP33
19 Jun 2011
Before the Romford Upminster Branch was electrifried it was signallined. There was a double semaphore signal which was always stuck in the same position except for when the DMU arrived and departed. It had its own signal box/garden shed with the name Romford Ground Frame.
Colin1501
10 Apr 2019
Isn't Bourne End to Marlowe similar to St Albans Abbey as described above, ie, a train 'locked in' to work the branch for most of the day?
mjmason1996
12 Aug 2019
Are the Ardrossan harbour/ Largs branches up on the Ayrshire coast signalled at their extremities?
Dr Hoo
10 Nov 2015
Hope Valley
Plenty of funicular railways are electrically powered but there are usually no signals at all.
A few are water-balance, of course.
