Trivia: Traincrew nicknames for routes
InkyScrolls
20 Jul 2022
North of England
There are various nicknames out there which traincrew have for lines they work, and I thought it might be fun to collate some of them.
Two examples I know are:-
  • "The Triangle" for the Leeds/Ilkley/Bradford/Skipton commuter lines, named after Shipley station (Northern, Skipton and Leeds depots)
  • "The Square of Despair" for the Exeter to Okehampton/Barnstaple/Exmouth/Paignton lines (GWR, Exeter depot)
Any others members are aware of?
Magdalia
1 Jan 2022
The Fens
In steam days, many train crew would refer to their hilliest and most difficult to work route as the Himalayas or the Alps. At Cambridge the Ipswich route was the Himalayas.
Not long ago I knew a retired driver at Cambridge, who still referred to the GN Hertford loop as the New Line, even though it opened in 1924.
Caleb2010
25 Nov 2015
Dufftown
Not very nice I know but I have heard crews refer t the Seaford branch as the ’A**hole of Sussex’!
contrex
19 May 2009
St Werburghs, Bristol
The Wimbledon and Sutton line is famously the 'Wall of Death'.
The New Guildford line opened on 2 February 1885...
Flange Squeal
17 Jul 2012
I believe prior to Okehampton’s full reopening giving a fourth branch, these routes were known as the “Triangle of Doom”.
As briefly mentioned above, the route between London Waterloo and Guildford via Cobham is known as the New Line, and crew almost unanimously refer to trains over it as “New Liners”.
The Salisbury - Romsey - Southampton - Romsey service is commonly referred to as the “Romsey Rocket”, and perhaps less commonly as the “Figure of 6” due to its shape.
Before the Guildford to Ascot service was split in two, these were generally referred to as “Ascots” (eg I’ve got Triple Ascots all week!). But since they were split, the Aldershot to Ascot services have remained known as “Ascots” while the Farnham to Guildford services are generally referred to by crews as “Shuttles”. With the then-new Farnham to Guildford shuttles getting ‘Juliet’ headcodes after the split, I always thought it was a shame the Aldershot to Ascot section retained the original ‘November’ headcodes. Because the two services are closely linked and crews at some depots can often spend a whole day doing a mix of the two, it could’ve been fun if the Ascots became ‘Romeo’ headcodes so those shifts would be ‘Romeos and Juliets’.
Not sure if these count as such, as they are more shortenings/generic names… The Waterloo to Waterloo via Kingston or Hounslow services are generally known as “Rounders”, Chessingtons as “Chessies” and Sheppertons as “Sheppies”.
To distinguish the Waterloo to Portsmouth via Guildford or via Eastleigh services, these are sometimes referred to as “The Direct” (the line via Guildford being the Portsmouth/Pompey Direct) or “Tangos” (the phonetic for the headcode used on via Eastleigh services).
ilkestonian
6 Dec 2009
The Potteries
I believe several areas (ok, perhaps not routes) are known as the Crucible. Cos you always have to have a red before any other colour.
GW43125
8 Dec 2014
Woking Jn, Crewe South Jn, East Croydon to name a few...
I've heard the Mole Valley (Epsom-Dorking-Horsham) referred to as "the back road" (ie not up the mainline via Gatwick).
Expanding on the SWR theme, I've heard a fair number of guards call the 1Sxx (Woking via Hounslow) "Super Wokings"! I can assure you there's nothing super about that route at all... The normal 2Fxx via Surbiton are the less boring "Woking Bay" (no prizes for that one...)
"York flyer" used over the PA for the hourly Edinburgh, first stop York.
"The desert" for the berks & hants (Newbury-westbury-castle cary-taunton), as it's a long and boring hour!
Ashley Hill
8 Dec 2019
The West Country
In his books Adrian Vaughn refers to the old line between Didcot and Newbury as The Gold Coast. In the same anecdote the line from Newbury to Westbury as the Toot & Bunny. He doesn’t explain the reasoning behind them.
Russel
30 Jun 2022
Lichfield
Is Seaford really that bad?
Last time I visited before the 313s were binned, it came across as just another unremarkable seaside town.
THC
21 Sep 2009
Stuck on the GEML
The line from Claremorris to Collooney through Mayo and south Sligo was always known by railway staff as the "Burma Road" and that name stuck locally for many years after the railway's demise.
West on Track said:
Where, one might ask, did "The Burma Road" nickname for the Collooney to Claremorris railway originate?
The answer lies in the difficult terrain through which the railway runs, traversing both bogland and rocky landscapes. Clearly, it must have required great engineering skills in its construction at the close of the nineteenth century. Inspired by the infamous "Burma Road" built, as a "supply" line, by British and other prisoners of war during the Second World War through the jungles of Burma, the Collooney to Claremorris line was nicknamed "The Burma Road", a title which endures to this day.
THC
driver9000
13 Jan 2008
Preston to Ormskirk is known "the bumble".
Lostock Hall Jn to Farington Jn is the "Back line".
Bishopstone
24 Jun 2010
Seaford
Seaford is lovely.
The other direction from Brighton, however, is the Wild West Coastway.
NSE
3 Mar 2010
It’s not that it’s bad, but all Brighton Drivers sign it from the outset and to begin with it can be a bit death by Seaford. Plus when you’re new and on a spare turn and something goes wrong, even if the problem is in London or Portsmouth, it’s highly likely you’ll cover Seaford to allow a driver from a higher link to be taken from the Seaford to cover Portsmouth etc. so naturally, a lot of crew are a bit bored of the route, hence possibly making negative comments about it.
david1212
9 Apr 2020
Midlands
Wasn't the Alton to Winchester line referred to as 'Over the Alps' in the distant past?
Yes
The area including the tunnels for all lines into Birmingham New Street.
The long closed line from Dumfries to Stranraer was 'The Port Road'.
'Quarry Line' for the route on the London to Gatwick/Brighton line in the Coulsdon area that bypasses Coulsdon South, Merstham & Redhill stations. Was there once a quarry along the route, is the name from the excavations for construction or given for another reason?
Rescars
25 May 2021
AIUI so named because it was the route to the "Port" meaning Portpatrick, the location of the original harbour for the Irish mail traffic, rather than the newer harbour at Stranraer. At one time I think the line south from Ayr through Girvan was known as "The Stranraer Road"
E27007
25 May 2018
Over The Marshes, Ashford International to Hastings via Rye.
A "must-do" line, something of a time warp, such as Doleham Station.
NSE
3 Mar 2010
Yes
The tunnel just north of the M25 is the Quarry Tunnel, hence the line being the Quarry Line. Why the tunnel is the Quarry Tunnel I don’t know however.
DelW
15 Jan 2015
There was a chalk pit just to the east of the southern portal, called "Greystone Lime Works" by the OS. It was served by railway sidings from the original line.
The screenshot attached is from maps that predate Quarry Line, but the southern portal is just south of Joliffe Row and adjacent to the line into the quarry. Unfortunately later maps showing Quarry Line are divided at the grid line in the middle of the image.
(Map image from National Library of Scotland website)
cadder toad
2 May 2015
These two came up recently on the forum. The Lanky for the West Coast ML south from Carlisle and the Sou West for Glasgow- Carlisle via Dumfries
Calthrop
6 Dec 2015
The following may make me disliked as a highly annoying nitpicker / pedant; but per my understanding, "Burma Road" does not, historically, refer to -- as per @THC's post as above, and as per linked article cited therein -- "[the infamously-] built as a 'supply' line, by British and other POWs during the Second World War, through the jungles of Burma". That truly infamous project, was Japan's World War II "Burma -- Siam railway" (venue of renowned "bridge on River Kwai" business): in the far south of Burma (Myanmar) and mid-Siam (Thailand) -- purpose, to link the two countries' metre-gauge rail systems, in the interests of the Japanese war effort. The historical Burma Road -- a literal road -- ran from Lashio, a good way north in Burma (Myanmar); north-east through horrendous mountain terrain, to Kunming in China -- built in 1937 -- 38: its purpose being, to convey supplies to China during the then war between that country and Japan -- the thing being done at the behest of the Western nations, which supported China in that conflict. The road had subsequent World War II involvement. The road's building probably took a hideous death-toll; but POWs did not feature -- one hopes that the labourers were, essentially, willing local folk.
One can figure that in their "nicknaming", the railwaymen in Ireland perhaps confused / conflated the -- roughly mutually contemporary -- genuine road "up north", with the rail horror further south ...
MattSGB
16 Sep 2023
Smethwick
I've overheard train crew referring to Worcester to Birmingham via Kidderminster as "The Dark Side", presumably because it goes through The Black Country.
RPM
24 Sep 2009
Buckinghamshire
Aylesbury Vale Parkway to Neasden South Junction is known as "The Met", for obvious historical reasons. Aylesbury to Marylebone via Wycombe is referred to as "The Western", or "Round the Houses".
Absolutely not. Seaford's a great little seaside town and I'd recommend the museum in the Martello tower - last time I was there it had lots of old hi-fi's from the 70's and 80's (plus it's a Martello tower - what more could you want !)
Agree - one of the best, most characterful lines out there IMO.
I've heard Ashford - Ramsgate via Canterbury West referred to as "the branch" by staff before.
bunnahabhain
8 Jun 2005
The Jolly Joint Line for Lincoln to Peterborough, mostly Nottingham crews this one as it used to be top link work and were very pleasant 5 to 7hr length turns.
Railcar
27 Nov 2017
Off topic, the bingo caller says "Five and Nne" and the chorus of punters all bleat "The Brighton Line!"
