The latter. Dedicated standby rescue locomotives are a relatively recent ideaRandom question but I searched and didn't see an answer: did the 1960s TV show get its name from the rescue locomotives, or did the locomotives get their name from International Rescue?
I don't think in the days of depots across the country with, usually, spare engines parked that there were dedicated "rescue" locomotives.Random question but I searched and didn't see an answer: did the 1960s TV show get its name from the rescue locomotives, or did the locomotives get their name from International Rescue?
Following introduction of the Mk4 coaching stock on the East Coast Main Line in the early 1990s, British Rail identified the need for a dedicated pool of locomotives equiped with electric train supply to rescue trains that had failed.
Although a spare freight locomotive could be used to move a stranded train, an electric train supply was necessary to operate the air-conditioning and power doors.
Four Class 47 locomotives were used, stationed at strategic locations along the Anglo-Scottish route. York Intercity Control nicknamed them 'International Rescue' and coded the loco's Thunderbird 1, 2, 3 and 4 after the rescue craft in the classic TV series.
The term gained wider recognition after one of the loco's, 47520, was officially named "Thunderbird" by Gerry Anderson (creator of the TV series) at London King's Cross in December 1993.
I'd have thought the multiple coupling standards from the 80s onwards have been a factor too, a situation exacerbated post privatisation.The Thunderbirds TV series was in the mid 1960s. In those days there was almost always a locomotive and traincrew not too far away. To take the ECML as an example, there would be locomotives and traincrew at Finsbury Park, Peterborough, Doncaster, York and Gateshead.
At termini and other loco change points it was usually possible to do stepping up to cover failures. Where trains were booked pairs of locomotives, they could be split. This was a favourite at Norwich.
Dedicated Thunderbird locomotives was a consequence of the second stage of sectorisation, when locomotives were allocated to sector pools and not supposed to be used by other sectors except by prior arrangement.
Yes they did
Believe there was a Scott Tracy, a Virgil Tracy, an Alan Tracy, a Gordon Tracy, a John Tracy, a Jeff Tracy, a Lady Penelope as well as Tin Tin, Brains, Kyrano, Parker, The Hood, Tracy Island, Firefly, The Mole and FAB 1.Didn't Virgin name all their 57/3 "Thunderbirds" after characters from the programme?
A moment’s silence for my unfortunate father who laboured under the misapprehension that Kyrano was in fact called “Guano” until I pointed the locomotive out to him one dayBelieve there was a Scott Tracy, a Virgil Tracy, an Alan Tracy, a Gordon Tracy, a John Tracy, a Jeff Tracy, a Lady Penelope as well as Tin Tin, Brains, Kyrano, Parker, The Hood, Tracy Island, Firefly, The Mole and FAB 1.
York and Darlington also had standby locos in the 1950s and probably earlier - generally an A2 at York and an A3 at Darlington.There was a long history of "standby traction" at key centres , sometimes using station pilots taken off their normal work to help out in a failure scenario. Reading GW for example had a 4-6-0 available to hand to take over any ailing loco. I believe one GW panner was pressed onto a main line working one day on an up express from Leamington , until a proper main line loco could be found on the route.
Taunton likewise commonly had a Hall 4-6-0, most often old stalwart 4932 Hatherton Hall, fully coaled on west end pilot duties, drawing back coaches from terminating locals, but ready to go anywhere. It normally faced Up, which was a bit unfortunate because when it was seen to be required suddenly it was mostly into the shed turntable pronto, and to head Down.There was a long history of "standby traction" at key centres , sometimes using station pilots taken off their normal work to help out in a failure scenario. Reading GW for example had a 4-6-0 available to hand to take over any ailing loco. I believe one GW Pannier was pressed onto a main line working one day on an up express from Leamington , until a proper main line loco could be found on the route.
In the 1970s I had a 1962 Triumph Thunderbird motorcycle, a 650cc twin. Marlon Brando rode an earlier (1950) model one in the film 'The Wild One'. Bikers often called them 'T-Birds'.Prior to that term 'Thunderbird' was a name quite likely derived from Native American folklore, being a mythological supernatural spirit creature of considerable power and strength.
