Trivia: Stations where terminating trains reverse outside the station
TheNewNo2
31 Mar 2015
Canary Wharf
On the Underground, Morden and Heathrow Terminal 5 would be examples - in both there's a depot or sidings beyond the platforms.
Manchester Metrolink still uses this system at Piccadilly, as trams still terminate/start there mostly the extra trams to/from Media City UK.
At various times Metrolink has timetabled services to turn back at Etihad when there is no event on there. This seems to be to about avoiding too many services trying to turn at Sheffield Street.
PHILIPE
14 Nov 2011
Caerphilly
Liskeard isn't the same. Combe Junction is a service stop on the line (admittedly only two trains M-S are scheduled to stop there but it isn't a terminal, otherwise all trains would stop there. It is only a consequence of line closure that trains have to use it for reversal of direction. Operatiionally, it is more like Cromer, Colchester Town and even Eastbourne.
At Liskeard terminating trains from Plymouth arrive in the Down Platform and have to go ahead to crossover and return from the Up platform.
Kite159
27 Jan 2014
West of Andover
I believe the Altrincham - Piccadilly services terminate at Eithad during the day, used to be Bury services but got switched over with the 2CC opening.
philthetube
5 Jan 2016
Also Amersham on the Met and Harrow on the Bakerloo, though in both cases it is possible to reverse from the arrival platform.
route:oxford
1 Nov 2008
As the OP asked about examples elsewhere in the world, New York Central Terminal had several of it's platform lines on both levels leading to a balloon loop. This was precisely so the trains could be cleared quickly to and from the depot sidings for servicing, in this case the sidings being within the station footprint and alongside the platform area. I believe only one of the loops remains in use, at a much reduced level.
Isn't the loop in order that the seats face the correct direction?
From experience, Amtrak "airline" seats tend always to face the direction of travel.
iain-j
2 Jul 2015
Musselburgh
Interesting idea for a thread.
IIRC Newcraighall was like this (before the Borders extension), because the one-in-a-million gradient at the station as too steep to be used for the driver to change ends (?).
Was this strictly enforced/observed? I have vague memories of services terminating there, sitting for a while (staff having a chat on the platform) and then returning back to the Waverley. While I might be wrong I'm pretty sure that was what happened.
rebmcr
15 Nov 2011
St Neots
The Manchester Metrolink used to operate like that at Piccadilly station. Trams would terminate in the inbound platform in the undercroft, run off to the turnback siding to wait their time then return to the outbound platform to start a new journey. Which is also exactly how Neilston station operates on Network Rail.
As an uninformed child I always assumed a balloon loop connected those portals.
On the T+W Metro, St James is a good example.
PeterC
29 Sep 2014
I can think of plenty where terminating trains run through to a siding but where there are through services as well. Also a few, such as Chesham where sidings have been removed and the buffer stop is now at the end of the platform.
If you ignore the LTS lines Upminster has lines through to the District Line depot.
AndyW33
12 Aug 2013
Lancaster
Northbound Virgin services terminating there actually run on to and reverse at Carnforth. I don't know if any currently do, but it was a past regular occurrence.
The trains that start southbound from Lancaster to Euston in the early morning now arrive ecs from the south and use Platform 4 without going to Carnforth. The evening train from Euston that terminates at Lancaster turns round in Platform 3 and heads back south ecs.
The track and signalling layout introduced with electrification didn't allow trains to turn round from the south using the same platform, or at least not with both trains carrying passengers. A few years ago signalled southbound passenger departures from Platform 3 became possible, but only currently happen during engineering works or disruption. It was always possible to turn trains round by crossing them empty from the down side to the up, at either end of the station, but this involved changing ends while the train was blocking the WCML, not a great idea with 11 car trains!
Carnforth provided a loop for changing ends in, and avoided lengthy platform or line occupation at Lancaster, which would otherwise impact the Manchester-Barrow/Windermere services.
anti-pacer
5 Jun 2013
Wakefield Westgate for the Huddersfield trains. They go up to Wrenthorpe sidings after arrival, and wait there until just before the return working.
lejog
27 Feb 2015
I agree that this must be common, it certainly is at stations local to me. At Hebden Bridge, terminating trains can run through the station in either direction. Terminators from the west run through the station to use the crossover to the east of the station. Terminators from the east usually just reverse to the crossover, but if the dwell time is too high (as was usually the case with the Leeds-Brighouse-Hebden Bridge service before it was extended to Manchester) trains run through to the west to Hall Royd Junction to turn.
Terminators at Todmorden from Manchester run through to the Tod Curve to turn. Terminators from Leeds run through Halifax to the sidings to turn. While I don't think there are any terminating services running through at any of these stations in the current timetable, there have been examples of all of these in the last 4 or 5 years.
Emblematic
14 Aug 2013
That would certainty be one of the uses historically, but now most services are suburban EMUs with mixed direction seating (some stock had reversible seating, but not sure if any remains now.) Nowadays Amtrak use Penn Station for all of their services, other than at time of disruption, and only one of the loops (can't remember whether upper or lower level) remains open.
At the time Grand Central was opened steam traction was banned and most of the trains would have electric locomotives that were taken off at the limit of the third rail, which wasn't very far away. As I doubt they had push-pull technology the loops would save a fair amount of shunting of locos.
Amtrak's Superliners had reversible seating as built and all seats would face forward in the Western long-distance trains they formed - both may still be so but it's a long time since I visited. The preference was to turn the entire train on a convenient triangle, probably because this kept the sleepers at the back. Superliners never worked into Grand Central but I think the heritage stock they used on the Lake Shore at the time (1986 and 1990) was also fully forward-facing.
To get back-ish on topic, I believe New Jersey Transit runs some of its Penn terminators empty through to Sunnyside Yard (west end of Long Island). And I've an idea the Long Island turns back in the sidings to the west. So this could be a non-terminal terminal in both directions.
jopsuk
13 May 2008
Bank on the DLR uses this idea- as will services terminating at Paddington on Crossrail. For metro-type services, especially if you can have clearance not to verify that the train is fully empty, it can be much more efficient than having terminating/departing trains crossing in the station mouth. Ideally though you want two sidings to provide for failures
Parallel
9 Dec 2013
Not sure if it's been mentioned, but trains terminating at platform 1 at Paignton have to shunt across to platform 2 to depart, I believe passing another level crossing (twice) on their way.
Tremzinho
13 Nov 2012
Liverpool Central Low Level used to run through to a reversing siding. A second driver used to get on at the terminus so that they could reverse quickly without having to walk through the train.
Since the building of the loop line and closure of the high level station, the Northern Line now use these platforms and it's become a through station (although 8 trains an hour still terminate there). I haven't seen the reversal siding used in years, but I believe it's still operational.
61653 HTAFC
18 Dec 2012
Queens Park terminators on the Bakerloo would be an example.
As for Halifax terminators, there is one from Leeds each evening but from the Brighouse direction. Not sure what it does upon arrival though.
lejog
27 Feb 2015
True. It waits 10 mins, then runs in passenger service through Bradford back to Leeds, so I've always thought of it as a circular service. But it's shown in timetables as a Haifax terminator, so if this counts, it means Halifax can have terminating trains running through in both directions, as well as Hebden Bridge.
Halifax also has the 180 morning service to Leeds from the Brighouse direction, although that's a starting train that runs through rather than a terminating train.
Strathclyder
12 Jun 2013
Clydebank
Dalmuir? Trains that terminate at Platforms 1 & 3 run empty to a holding siding west of the station for cleaning etc. before running back to the station to take up their next service at either Platforms 2 or 3.
xotGD
4 Feb 2017
Am I right in thinking that some terminating services at Embsay run through the station to reverse, but with the passengers still on board?
Kite159
27 Jan 2014
West of Andover
Basingstoke terminating services sometimes have to vacate the station to a siding on the west side when a XC service is due. Once the XC service has departed the 450s roll back in to form the next Waterloo stopping service.
Ianno87
3 May 2015
Last time I checked, there were still a couple of daily trains booked to use the Reversing Siding - presumably for route knowledge retention at least.
InOban
12 Mar 2017
I should have thought of that one. I assume that platform 1 is West bound from Westerton? In which case these trains now usually run through to Dumbarton, and I assume reverse in the loop there.
Via Yoker terminators presumably usually run into the bay platform ?5, although I've been on one that did as you suggest.
urbophile
26 Nov 2015
I seem to remember that in the first few years of Northern Line operation, trains that terminated at Central (usually Ormskirk and Kirkby ones) routinely continued into that siding and reversed into the northbound platform (2?). More recently they have terminated and started in the same platform, one or the other. But I think some of the extra Southport terminators still use it.
Kneedown
29 Dec 2007
Nottinghamshire
Phase 1 of the Robin Hood line, when trains terminated at Newstead. It was a requirement for trains to offload the passengers before continuing forward ECS for a short distance, where the Driver would change ends and return to the platform. I'm afraid I don't recall the reason for this, only that it was something to do with the signalling or track circuits.
Not sure if it counts, but some EMT services terminating at Worksop continue over the crossover to reverse, or on to Mantonwood. Same applies at Newark Castle for the terminators.
cactustwirly
10 Apr 2013
Bedwyn, the train switches platform via a siding just beyond the station.
Great Malvern, terminating services go via Malvern Wells siding
