Trivia: station codes with letters not in the station name
alistairlees
29 Dec 2016
Not rail related but the airport code for Aberdeen is ABZ. Why the Z?
It just got the short straw I expect. All of ABA to ABY are used for other airports. There are a lot more airports globally than there are stations in Great Britain.
SargeNpton
19 Nov 2018
My presumption that the first letter of the code still has to be the same as the first letter of the station's name is probably incorrect, then! CRS, of course, goes back nearly 40 years, and other systems have come along since which have their own rules. Originally, I believe, only stations served by reservable trains had 3-alpha codes; the rest got theirs when the Disabled Persons' Reporting System (DPRS) was introduced in the late 1980s. Needless to say, neither CRS nor DPRS was concerned with Underground stations!
For National Rail stations, CRS codes have to have the same first letter as the station name as it appears in a central database called CORPUS. London terminals are an exception to this as the "London" prefix was not used in the early 1980s when CRS codes were widely adopted. That Mottisfont & Dunbridge still uses DBG is an oddity in that the station name has been updated everywhere except in CORPUS! LHR for Heathrow is another oddity.
Z series codes are generally used for stations under the control of London Underground or Docklands Light Railway. Where control of a station moves between National Rail and London Underground the CRS code will often change as a consequence - and there are some stations with separate CRS codes for both sides of a joint station.
X series codes are used for certain operating locations and for some non-rail passenger locations (bus stops, ports, Irish stations, other third-party rail systems, tourist attractions). Whether a non-rail location gets an x-series code or a "proper" CRS code depends on a number of factors.
Changing the CRS code causes a number of problems in various systems so is done as infrequently as possible.If a location changes its name but retains the same first letter then the existing CRS code is normally retained (e.g. Bicester Town to Bicester Village). If the station name changes completely then the CRS code has to change (e.g. when Smitham became Coulsdon Town then SMI changed to CDN).
Finally, there are a number of stations that have two CRS codes as a legacy of DPRS, such as Tamworth (TAM/TAH) but only the main CRS code is used for retailing these days.
adrock1976
10 Dec 2013
A thought that came into my mind here is that there could be a possibility of the Z referring to Shetland (old Viking name was Zetland).
Aberdeen is also a gateway for cargo to Shetland too, especially mail deliveries. Anything addressed for the postcodes of AB and ZE all go to Aberdeen.
14 Apr 2014
Wigston
Surely ALE was used when Virgin Trains we’re stopping short at Liverpool South Parkway. They waited at a signal which was Allerton and I’m sure showed Allerton as the destination on the trains and at Euston
Ianno87
3 May 2015
The high level platforms still use ALERTN as the TIPLOC, which may explain it.
SargeNpton
19 Nov 2018
Network Rail doesn't like amending TIPLOCs so there are several around the country that relate to a station's former name. In one instance a station has a TIPLOC for a name it never used... The TIPLOC for Imperial Wharf is CSEAH, as the station was originally to be called Chelsea Harbour.
pdeaves
14 Sep 2014
Gateway to the South West
And that's before we even get started on how many Highbury & Islington seems to have picked up!
XHZ - East London line
HHZ - special Olympic Games code
HHY - Great Northern line
ZHI - Underground
HII - North London line
Only two have letters only in Highbury & Islington.
ValleyLines142
25 Jul 2011
Gloucester
Bedford is BDM (for Bedford Midland).
Also St Johns in London is SAJ (SAint John's but technically it's the former).
bussikuski179
8 Aug 2020
Helsinki, Finland
If you think that’s odd, look at Málaga! The code there is AGP. Sure, A and G are in the name, but why AGP though? There are a lot of airports so some get odd codes.
Ianno87
3 May 2015
Aeropeurto Gran Picassio (after one of Malaga's most famous sons)
Edit: Reading more, I think that's just an urban legend, and that the obvious codes beginning with M were already taken.
So AG from Malaga, plus a random letter, was what it got!
30907
Officially: Malaga-Costa del Sol Airport (only since 2011), sometimes called Pablo Picasso Airport.
