Trivia: Shortest possible loop in the country?
Mutant Lemming
8 Aug 2011
Following on from the "longest possible loop" thread:
http://www.railforums.co.uk/showthread.php?t=109044
Using the same rules, what is the SHORTEST possible loop. I nominate Newcastle Central to Newcastle Central (Newcastle Central-King Edward VII Bridge-High Level Bridge-Newcastle Central).
Can you actually make the journey as a passenger by train though ?
Would suggest an alternative being Glasgow Central to Glasgow Central via Cathcart.
Mutant Lemming
8 Aug 2011
Actually am not sure of my own suggestion and the one above as they aren't really starting and finishing at the same point. Not sure if the Glasgow Subway would count either as it isn't 'mainline'.
Radlett stone terminal - Radlett stone terminal?
I could arrange a wrong routing ;)
WestCountry
31 Dec 2010
Cambridge, UK
Kennington loop on the Northern line (Kennington - Kennington, where all the Charing Cross trains go through when they terminate there to go back northbound)
Does that count? It's not a 'loop' in the sense that you end up in the same place as you started and can keep going around without changing direction.
Clapham Junction - Herne Hill - Tulse Hill - Clapham Jn is fairly tight.
David Goddard
8 Aug 2011
Ely
Ely West Junction - Ely North Junction - Ely West Junction.
The Ely West Curve has always affectionately been known as just "the loop"
WestCountry
31 Dec 2010
Cambridge, UK
Did not know about the changing direction - as I saw the GLC - GLC loop above I assumed not (unless there is a part of GLC I'm forgetting!)
Not my thread, just trying to guess at the OP's intent.
The OP's example is an actual loop, as is the impressive Radlett one. I don't think any of the others are. Maybe just mention on posts which category it's in?
theageofthetra
27 May 2012
Beckenham
When it was open - Pilot halt - Pilot Halt via the Dungeness loop on the RHDR. Also there are many European tram systems which use single cab stock & have turning loops often with a very sharp radius. I believe a loop is being proposed at Croydon on Tramlink.
GrimsbyPacer
13 Oct 2014
Grimsby
What about:
Meadowhall (S. Yorks) past the disused Rotherham Masboro' station then at Swinton going back via Rotherham Central?
Does that count as a loop?
Birmingham New St-Soho-Aston-New St is certainly a circle. Not the smallest though.
You can go the other way too: Wolverhampton-Bescot-Soho-Tipton-Wolverhampton, and various useful combinations of these two.
Then there's New St-St Andrews-Lifford-Bourneville-New St.
Lee_Again
29 Sep 2007
Stevenage
What about Newcastle to Newcastle over the bridges. Pretty sure you go around in a loop if signalled correctly.
