Trivia - Shortest Journey Requiring Two Changes
randyrippley
21 Feb 2016
Think there's a Parlimentary that does Heysham docks to Carnforth, but other than that Carnforth > Lancaster > Morecambe > Heysham unless you are on the very scarce Lancaster > Heysham "boat" train?
If you're going to Heysham the train starts at Lancaster, reverses at Morecambe. No changing at Morecambe.
And there's no Heysham-Carnforth "parliamentary", though there is one daily Barrow train which runs Lancaster-Morecambe-Carnforth
BeijingDave
26 Jul 2019
If it's 'realistic' journeys people would actually make, then Widnes to Chester must have quite a flow of road traffic (commuter and weekend shoppers), yet would always require two changes on the train AFAIK.
Railcar
27 Nov 2017
West Croydon to East Croydon? Under a mile. Change at Selhurst or Norwood Junction. Or take a tram (or a bus).
xotGD
4 Feb 2017
Points of clarification:
1. I was not including London Underground, only proper trains.
2. I was only considering journeys where it is impossible to do it with one change, even by a much extended route. So, for example, Euston to King's Cross is one change at Edinburgh Waverley!
Shaw S Hunter
21 Apr 2016
Over The Hill
Since Merseyrail started running to Chester it has been a single connection journey via Lime Street. So that's 30 years and counting!
Farigiraf
23 Jul 2023
Bridge on the River Cam
North Camp to Ash Vale, about 800m, change at Ash+Aldershot, Redhill+Clapham or Wokingham+Clapham
Edenbridge to Edenbridge Town, change at Redhill and East Croydon
Clock House to Kent House, change at Lewisham and Victoria
Streatham to Streatham Hill, change at Tulse Hill and West Norwood (There used to be a Tulse Hill-Streatham Hill parliamentary/limited service but I don't think it runs anymore)
xotGD
4 Feb 2017
Pontefract Baghill to Pontefract Monkhill.
Change at York and Leeds, so quite a long journey.
I'm looking for examples where the rail journey is shorter, rather than just the start and end points being close together.
urbophile
26 Nov 2015
One these days; Liverpool South Parkway. Though not very frequent.
StephenHunter
22 Jul 2017
Is Overground OK?
If so, Romford to Rainham.
urbophile
26 Nov 2015
What's improper about LU?
Farigiraf
23 Jul 2023
Is Overground OK?
Emerson park is a bit closer, and then your other option is changing at Stratford, which might be more stressful. If we ignore fact that there's a direct bus between them then that might be the perfect answer
Also, Grays/Tilbury to Ebbsfleet/Gravesend. If you are someone who gets very seasick then this would be a legitimate journey.
Route: (if we exclude tube/DLR as the OP said) Grays/Tilbury-Upminster-Romford-Farringdon-Gravesend/Northfleet (now if Elizabeth line is off the table then we would have to go via the north London line)
As the crow flies, Southend-on-Sea to Sheerness, about 10-15 minutes (?) on a boat, by train 5 (4 at peaks) changes - Southend(Vic, Central on weekends)-Stratford-Farringdon-Rainham/Chatham-Sittingbourne-Sheerness
Hessle-Barton, if the bridge is closed, Hessle-Doncaster-Habrough-Barton
InkyScrolls
20 Jul 2022
North of England
Correct. Carnforth/Lancaster/Morecambe/Heysham are all at most one change apart.
Not anymore. The 0519 service starts at Lancaster and terminates at Morecambe, though it does use a Barrow crew.
xotGD
4 Feb 2017
Many of these suggestions are between places that are close together but require a long rail journey.
May I reiterate, I was looking for short rail journeys requiring two changes.
Farigiraf
23 Jul 2023
Tooting to Streatham Hill is a good example of what the OP wants (This is not BusUK forums so no nitpicking about buses please!)
Back in the day*, Bromley N to Lewisham was one - but there have been regular trains from Grove PK to Lewisham for several decades.
Bromley N to Lee would fit though.
*after the last through trains off the branch went in the early 80s.
urbophile
26 Nov 2015
How do you get from Catford to Catford Bridge? I remember Geoff Marshall did a video on this but I can't remember how he did it by train (walking is easy of course).
Springs Branch
7 Nov 2013
Is Upton - Wallasey Village a contender?
. . . a short, plausible journey by rail & minimal doubling-back (but suspect Kelvindale/Jordanhill via Anniesland & Hyndland will still win on rail mileage)
. . . in the past Merseyrail had run the very occasional West Kirby - Loop - New Brighton (or vice versa) train, but there doesn't seem to be any of those in current timetable.
[EDIT] According to eNRT mileages, KVD-JOR is a mere 2¼ miles by rail.
UPT-WLV is ~4 miles via Birkenhead North (BKN - WLV was a bit further than I'd guessed), so no contest - but comparable to the OP's Ardwick - Salford Central via Crescent.
