TRIVIA - Shortest Distance From Overbridge To Underbridge
tbtc
16 Dec 2008
Reston City Centre
Just a bit of fun... but admiring a model railway recently, I realised how common it is in such layouts to have the line going under a road then go over a road a very short distance afterwards.
So, using UK heavy rail, what is the shortest distance between a road bridge over a railway and a road bridge under a railway?
Norb
26 May 2014
To start us off, it's 248m from Stump Lane overbridge to Brunswick Street underbridge in Chorley
rebmcr
15 Nov 2011
St Neots
0m, as the Stockport-Altrincham line passes through the A34's junction with the M60/M56!
notlob.divad
19 Jan 2016
But it is 220m between the two bridges
At the same junction it is 47 metres on the Gatley to East Disbury line between the bridge under the slip road and the one over the M60 proper.
AndyNLondon
20 Jan 2014
And there I was thinking that 250m on the North London Line was a good find. (The bridge over Caledonian Road and the one under Roman Way - with Caledonian Road & Barnsbury station in between the bridges)
hwl
5 Feb 2012
West Norwood at 110m - Overbridge at one end of platforms and road under the platforms 5-6 cars along the platform. The Roads Over and under are directly connected along side the station unlike most other suggestions so far.
rebmcr
15 Nov 2011
St Neots
Is there not a bit with an over- and under-bridge sandwich? Perhaps I'm thinking of the M60-A6 junction further east, the one with the provision for the A6(M)?
NSE
3 Mar 2010
Whilst your examples are closer, I've always liked the one at Sanderstead where you leave the station, go left over the line, down along side it then right back underneath the branch (depending on where you're gong of course). Or, alternatively, come down Sanderstead Hill over the Oxted line and then continue down under the BML.
Lrd
26 Jul 2010
Does this railway still carry traffic? It's between two motorway slip roads with a motorway mainline above, another motorway mainline above that though slightly to one side, with two more slip roads above that.
https://www.google.co.uk/maps/@51.494756,-0.4953256,339m/data=!3m1!1e3
There are no passenger services on that line. Not sure about any freight. I used to pass it every day and always wondered where it went to but by the time I got home, I always forgot to check.
notlob.divad
19 Jan 2016
I'm not sure where you are referring too.
The closest I know of to the original question where the answer would be 0 involve 2 rail bridges or where the railway is on the top or bottom of the stack. But I don't know of anywhere that the railway threads through as the middle level.
I think the closest you can get to 0m is at Castlefield Junction where the railway threads through over a car park and under the Metrolink.
Dr Hoo
10 Nov 2015
Hope Valley
Between Cricklewood and Mill Hill Broadway the Midland Main Line is in a sandwich between the North Circular Road underneath and the flyover above.
AM9
13 May 2014
St Albans
There's also HS1 passing over the A282 northbound carriageway as it climbs from the northern portals of the Dartford Tunnel, then about 50 metres later, passing under the southbound carriageway as it climbs up the approach ramp to the QE bridge across the Thames. The line then proceeds down a steep gradient to the northern portal of the Thames (rail) tunnel. All of this is traversed at 186mph (rail) and 50mph (road).
EM2
16 Nov 2008
The home of the concrete cow
Cheating slightly but how about Knaresborough and Maidstone East? In both cases, the railway enters the station via a tunnel (which is a sort of underbridge) and leaves the station via a viaduct or bridge over the river.
Hophead
5 Apr 2013
Already noted, but I think I'm correct in saying that HS1 line speed is a mere 225km/h as far as Ebbsfleet (give or take a km or two).
